Question about Hotpoint Refrigerators
Hinge is broken on my hotpoint future RL 150
I want to know how to replace the hinge on my hotpoint future RL 150
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
  • 43 Answers
SOURCE: Replace door hinge on JVM1533WD002
Door Hinge replacement requires a Microwave Radiation Leak Test be performed after repairs.I am surprised they would sell you the part knowing this. You should have this repaired by a professional for SAFETY sake.
SOURCE: Door Hinge replacment
have you tryed taking the door screws out and put the new one in
Posted on Apr 02, 2008
IFIXALL
  • 868 Answers
SOURCE: Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Posted on Jun 06, 2008
  • 52 Answers
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
Hi, I have a hotpoint fridge/freezer future rf 175wp and want to change the doors from right hand to left hand hanging. Do I need to get new hinges? Thanks Dave Horn
Dave,
You should not need new hinges. As long as you have screw holes on both sides you re-use the same hinges, just flip the middle one over. The bottom hinge point, you will need to move the post from one side to the other. Hope this helps!
May 07, 2015 | Hotpoint Refrigerators
My refrigerator door on my Hotpoint is misaligned. Model Hth16bb. How do I realign it?
loosen hinges and adjust . a very common problem /. some will require the replace ment of the hinge if broken or worn out . hope this helped .mm
Oct 24, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Passenger door hinge spring mechanism is broken 97 gmc jimmy
The spring is likely "broken" because the pins in the bushings are worn. It's a common failure point on many GM vehicles. The hinge pins, bushings door check roller and spring can be replaced at most body shops for about $150-200.
Apr 23, 2010 | 1997 GMC Jimmy
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Replacing Door Hinge
You should be able to access the back of the hinge via the top of the machine removed.
Oct 07, 2007 | Hotpoint Ultima WD72 Front Load...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
