Question about Emerson Audio Players & Recorders
How does the microphone work on the emerson EM515
How do I activate the Microphone when connected to laptop ?
  • 238 Answers
SOURCE: My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Posted on Feb 14, 2008
SOURCE: pc microphone
i found a solution under the control panel. to configure some settings under the default view of the control panel, use the Ease of Access icon. this does not allow you to see the actual device. by switching to the classic view, use the Speech Recognition Option, which showed that i had 3 microphone drivers installed. all that needed to be done was to select the one i was using as the default.
Posted on Mar 09, 2008
SOURCE: problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Posted on Sep 02, 2008
  • 31 Answers
SOURCE: cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Posted on Mar 17, 2009
SOURCE: Logitech QuickCam Express: Microphone not working
The quick cam express and quickcam chats are the only two models built without a mic in the camera.
Posted on Sep 08, 2009
Microphone working
Click on call on the menu bar and locate Audio settings In the audio settings you will see Microphone it is possible in that drop box you will see two microphone name listed select the other one to activate the microphone
May 21, 2013 | Fujitsu LifeBook AH531
Tip
How to play computer sounds through microphone
<p>There may, of course, sounds from a microphone, because there is a speaker, but you can use sounds from a microphone or something speakers connected to the microphone system is played. Computer games, but might sound a bit complicated because they usually lead to loud sounds into the microphone to a number set. <br /> <p><br /> <p>1. Find the computer that you want to play sound. Go to Control Panel and click on "Hardware and Sound." Under "Sound" in "Changing the system sounds." You can access various Windows sounds by selecting them and clicking "Test". <br /> <p><br /> <p>2. External speakers to the sound card or audio output on a laptop. With active speakers is recommended, the stronger the better. Set the microphone in front of the speaker. <br /> <p><br /> <p>3. Connect the microphone and play the sound from computer speakers. That should pass the microphone for recording or performing live. <br />
on Jun 22, 2011 | Audio Players & Recorders
am sure you usually encounter this problem with skype. if so then
May 04, 2013 | Fujitsu LifeBook AH531
I'm trying to use Skype but it's saying my microphone isn't working. When I go into the sound option the microphone says it's not plugged in. I'm trying to use the internal microphone so how do I connect...
It's already plugged in so you must make sure it's activated in the BIOS. If it is then the microphone itself is faulty and you will have to replace it - this is a relatively simple and cheap job that you should leave to a repair shop: the laptop must be dismantled to access and replace it.
Dec 13, 2010 | Fujitsu AMILO PC Laptops
How to activate my builtin mocrophone
Dear
to activate builtin microphone do following step:-
1- double click on volume icon (right side down of ur desktop), Playback control window open.
2- In playback control window click on options>properties.
3- In properties windows u see "adjust volume for" area , here click on "recording".
4- while click on "recording" down u will see option for ur recording devices (Line In, Microphone,S/PDIF in etc ) select on microphone and click ok.
5- now u will see " Recording Control " window here select microphone and adjust volume for microphone
Ok now u will turn on ur Microphone Try to chat with anyone to ensure ur microphone is working.
Oct 22, 2008 | Dell Inspiron B130 Notebook
I just bought a GE Portable headset with detachable MIC
I had the same problem, but fixed it. All you have to do is:
(I have a Dell Laptop)
1. Go to the control panel
2. Go to the sounds, speech and audio devices
3. You are supposed to see the icon that belongs to your sound card (Mine is SigmaTel Audio), click on it
4. Activate the port where the microphone is connected, close
5. Configure your microphone as you normally would
6. It should work
Oct 10, 2008 | GE (JASHO97748) (3 Pack) Headset
How do i activate microphone
If you just reasently purchased then take it back and ask tham to sort it out.
Jul 28, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone on aspire 3680 not working
First u activate ur microphone connection.Click on Start - Settings - Control Panel - Sound and audio device Propeties - Advanced - Options - Properties - Select Mic in volume and check it.
Thanks
Feb 28, 2008 | HP Compaq Presario V5000T Notebook
Microphone is not working
Did your Microphone come with a Software CD?
Oct 23, 2007 | Labtec Verse 333 Consumer Microphone
51 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
