Question about Dell 810 All-In-One InkJet Printer
"USB has malfuctioned" after normal use for 2 weeks
I've been using this printer everyday for 2 weeks when it was taken out of the box. This morning I booted up, and tried to print out a shipping label. When I hooked up the USB cord, it told me that it had malfunctioned, and no matter what I've done, it won't recognize the printer. So far I've... -plugged it into another port -tried a new cable -restarted -uninstalled the printer -attempted to reinstall the printer (but won't let me because it won't recognize it) -checked to make sure the printer is indeed trying to recognize it as a USB device (it was) Any ideas?
  • 1 more comment
  • Alissa Aaa Jun 28, 2007
    I actually got it to work last night - but only on one of my USB ports. Apparently this is a really common problem when you're plugging & unplugging your USB devices a lot (whoda known?).
    I went into safe mode, and deleted the USB port root hubs & controllers, then rebooted.
    I added a new string in the registry, and let my computer sit for 30 min. w/o battery.
    Then I rebooted, reinstalled the printer... and it worked.
    Thanks for your reply, though!
  • Alissa Aaa Jun 29, 2007
    I didn't rate your solution, and it still gives me the option to rate it. And I thanked you for your help in my previous comment. There's no need to be rude.
  • Anonymous Feb 06, 2009
    my laptop is Sony Vaio PCG-TR1, my usb got malfuctioned and windows doesnot recognize it...i tried to looking for soft ware and could not repaired.
    please help me..thanks
    email me
    Scholar:
  • 77 Answers
First, check to see that you can make a copy. If you cannot you have a physical problem with the unit that we will have to address. If you can make a copy: Disconnect the printer from the computer Go to the Control Panel/Add Remove programs Remove the Dell printer program Go to the Control Panel/Printer and Faxes Click on File come down to Server Properties In the box that pops up go to Drivers Click on the Dell printer - click on REMOVE Reboot your computer Re-install the printer driver from the CD - It will let you know when it wants you to reconnect the printer. If that does not take care of it, PLEASE let me know before you rate this solution. Ed
Posted on Jun 28, 2007
  • Edward Paulinski Jun 29, 2007
    Thanks for the negative rating
Hp 3847 printer lost communication with the computer
Hi, Need more information. Connecting by Wireless or USB? When installing does it find printer correctly?
Jul 13, 2017 | Office Equipment & Supplies
Kodak Easyshare 500 will not stay powered on
It may be that the printer needs more power than the USB port can supply, so it shuts down. Mine uses a special cable with 2 USB plugs at the computer end and one plug at the printer end - this gives twice as much power to the printer! Image attached....
Feb 10, 2018 | Cameras
How do i get the receiving and sending fax report only once a week. Keep getting everyday and don't need it that often
As far as I recall with that model is that you either get it everyday, not at all or you print it when you need it.
Nov 29, 2011 | Sharp AR-M237 Copier
So i've been using a poulan pro 4218 all summer, ran like a champ for me everyday all day. then the crankshaft holding the clutch and sprocket snapped.. not a problem bought the part and replaced it....
Sounds like a carb issue, the L screw on the carb adjust the fuel mixture from idle to half throttle, i would richen the L screw by unscrewing 1/4 turn, this should improve the running, however there is a special tool to adjust the screws, part no. 530035560, the screws are fuel, not air screws, increase a shade more if it is still not idling or accelerating properly.
Oct 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cannot get my Lexmark Z2420 printer working--it has the wi-fi capability, but trying to connect it via USB. Should be plug-and-play but windows makes a sound like it recognizes it, but nothing comes up as...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/9xPHL4. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 26, 2011 | Lexmark Z2420 Printer
How do I see/get error codes for my 1988 4Runner? (idling prob.)
The check connector is located near the No. 2 relay box. Short terminals T and E1 of the check connector. (jump together)
2. Turn the ignition ON. do not start engine.
3. Read codes by the number of flashes of the "CHECK ENGINE" WARNING LIGHT.
4. System normal: blink every 0.25 seconds.
5. Malfuction Code: light will blink a number of times equal to the malfuction code.Between first digit and second digit, 1.5 sec
Between code and code 2.5 sec, between all malfuction codes 4.5 sec
6. The diagnostics code series will be repeated as long as the connector terminals T and E1 are jumped.
7. Codes are 2 digit numbers
Feb 11, 2010 | 1988 Toyota 4Runner
Kodak easyshare 5300 issue.
Call Kodak tech support and they will ship you a new printhead without any charge.
Jan 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark p6350 all-in-one not working
I am guessing that you're using the New improved windows Vista. If so, you need disconnect the printer power and usb connection. then remove the current driver for the printer and down load the current driver @:http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:571:0:0
The soft ware will tell you when to install the printer
Dec 30, 2007 | Lexmark P6350 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
