Question about Kodak EASYSHARE 5100 All-In-One Printer
I need replaces the printhead
Hi: i try to replace the printhead , i was call last week and the costumer find problem with printhead , i ready received the part i need instrution for change the new part .
  • greg_dulaney Jan 20, 2009
    cant get the old printhead out whats the trick before i break this thing?
First off, remove the cartridges. There's a small button/lever up under the top of the printhead that you have to press in, its in the very center. Once you press that in, it should pop forward and allow you to pull it out. In order to replace it, just pull the old one out, pull the yellow tabs off the new one and snap it in place and put the cartridges in.
Posted on Jan 21, 2009
Printheads in Designjet 510
Alexander, did you do the allignment after changing print heads?
Feb 01, 2014 | HP "designjet 510 24 in. inkjet printer"
Getting message "problem with printhead k and y" what do I need to do to correct issue?
You need to replace the black/yellow printhead, and if you are using generic inks it won't last for more than a week. The new printhead is around $50.00
Dec 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
I haven't used my Kodak 5500 printer in a little over a week and now I'm trying to print out pictures and with a new black cartridge, it's like there is no black ink. However, I just printed out a word...
Since that you already did a good troubleshooting cleaning the printhead and calibrating It and replacing the printhead., I just want to ask this How many times you already replace a printhead if its newly installed it means the problem is in the printer itself and for that you need to call kodak for printer repair toll free 1 800 421 6699
Now if the replacement printhead is more than a month and you already did all the troubleshooting it means the nozzle of the printhead is clogged you need to call kodak for printhead replacement
GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Colors missing on Canon Pixma
hi,
since you are ready to find a replacement if this doesn't work, you can try a few things by yourself.
see if the the jack connecting the printhead to the ink cartridge holders is intact(it is a source of many problems in these type of printers)
also. if there is too much heat emanating from the printer during use, its advisable to chuck it.
cheers
Jul 24, 2009 | Office Equipment & Supplies
Help with my k5400
It's possible you have one of the following problems:
  • Printhead is faulty
  • The printhead has expired (HP printheads have an expiry date which is written into the chip)
    In both of these cases contact HP support to request a warranty replacement (but try the ideas below first obviously :))
  • The printhead hasn't been inserted properly
  • The chip contacts are dirty or soiled in some way
    For these last two, try removing the printhead, cleaning the chip carefully with a cotton bud and then replacing carefully.
It's also entirely possible that you've been sold a lemon in which case you need to call the store you bought the printer from and get them to troubleshoot the issue with you and/or replace it/refund your money.
Hope that helps.
Jun 11, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Kodak 5100 all in one printer, 3802 code
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk or www.kodak.com
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Jan 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Printhead replacement
I don't just change the printheads, go to utilities and recover printheads.
If all printheads are playing up, che3ck the magenta cleaner, if it's over full it can cause all printheads to fail, this info was taken from a page on the HP web page, but ?I can't remeber where.
May 13, 2008 | HP DesignJet 1050c InkJet Printer
White stripes evident each time the printer is started up from cold
Those solid ink machines are designed to be left on 24 hours a day, 7 days a week. (it uses about $20 in ink to turn on each time)
When turned off the printhead nozzles can get clogged up with dry ink, which causes white stripes. Running the eliminate light stripes routine purges the printhead (using another $10 or $12 in ink). When it becomes a continuous problem the printhead needs to be replaced....very expensive and time to get a new printer !
Jan 12, 2007 | Tektronix Phaser 860 Thermal Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
