Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
Won't start
By hje243 on Jan 19, 2009
I have a Propane Reddy Heater Model RLP50VA. When I start it, it will run for a few seconds then it cuts off. If I can get it started again it does the same thing
Same Problem
Mar 29, 2009
-   The heater runs on oil. -   Guest
Jan 29, 2009
-   My motor is running backwards. I use my air nozzle from my compressor and blow in the rear of the unit and it'll run fine. As soon as it shuts off it tries to start but runs backward and shuts off. -   jghandymann
Solution #1
posted on Mar 29, 2009
Somewhat Helpful)
jr2250b
Rank: Apprentice
Rating: 75%, 2 votes
if the propane cylinder is almost empty you maybe getting a concentration of murcapton(spelling?)this odorant is added to propane so it has an odor.when the gas gets low in the cylinder you can pull more odorant that may have settled in the bottom of the tank over time. there are other reasons since you are dealing with an unvented heating product , such as other odors fron oils,cleaning products, paint, etc. there could other problems so you may want to take it to your local propane store. jr
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
I plug my ready heater in and it will run for a few minutes and it will start to smell like fuel and... (More)
Answer
I have a rllp35a propane reddy heater that will run as long as I hold the automatic control button... (More)
Answer
shuts off after about 5 mins and won't stay lit after.
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
