Question about Pentair MasterTemp 400HD - 400,000 BTU NG CUPRO NICKEL
Manual dela caldera MasterTemp 400HD - 400,000 BTU NG CUPRO NICKEL
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: what size gas line for 400,000 btu water heater
Thank you for posting your question here on Fixya.com.
Is it Natural gas or LP gas?
What pressure does your gas provider supply it with? (It will usually be low pressure, ~14"WC if NG)
How far from the access point you will get gas from to the heater?
Once you have answers for these three questions use the installation guide found on pages 13-14 of this manual to determine the proper gas line size. Be sure if you use a different material pipe, like CSST, you adjust the pipe size based on manufacturer's recommendations. 1" copper and 1" CSST are NOT equivalent!
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Feb 12, 2011
SOURCE: Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Posted on Jul 23, 2011
What are common issues with Pentair 400k Natural Gas IID Cupro-Nickel MasterTemp Heater?
Common is so generic.
Many issues can crop up, not necessarily exclusive to any one specific brand of appliance, such as a heater or directly with Pentair.
Overall, they make a good heater!
Keep your filter clean; ensure that chemistry is always balanced, and take care of issues as they arise, immediately (as problems happen to any heater of any brand) and you should have a long happy union with a heater.
Apr 01, 2015 | Pool & Spa
Why mastertemp wont turn off
Does it stay fired or does the fan just run for a few minutes after you shut it off?
Jul 17, 2014 | Pentair 400k Natural Gas IID Cupro-Nickel...
How to install firemans switch entire 400hd
if the timer has the fireman switch attach the 2 wire to the heater and the fuse panel inside you will see a fuse with a yellow jumper wire ,remove the jumper and connect your switch
Apr 01, 2014 | Pentair MasterTemp 400HD - 400,000 BTU NG...
Mastertemp heater shuts down
check gas pressure could be running to hot and overheating or burn tubes clogged
Dec 09, 2013 | Pentair Mastertemp Pool & Spa Heater Dual...
Error code 128r13
make sure spa setting heat is enabled
Mar 30, 2013 | Pentair MasterTemp 400HD - 400,000 BTU NG...
I have a mastertemp pentair heater. No error codes. Pool heater works fine-- spa heater button will not light or operate. Any sugestions?
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
Sep 11, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
We just installed a new Raypak 400k BTU cupro nickel NG heater. It's connected to a Jandy PDA controller. If I set the temperature above 86 on the PDA, the heater will cut off at 86. If I take the heater...
The heater need to be set to max heat and then let the controler control it. Which ever is set the lowest will stop the heater. Good luck and let me know how you do.
Apr 02, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Feb 21, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pentair MasterTemp 400HD - 400,000 BTU NG CUPRO NICKEL Logo
32 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
