Question about HP DeskJet 3745 Printer
Printer does not want to work
I have installed my printer and it does not want to print
Need printer software
Posted on Feb 22, 2009
Installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
2490MF
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
Aug 21, 2008 | Konica Minolta magicolor 2490MF Laser...
The printer is not printing
Dear emnyirenda, for various problems a printer can't print. See which one is yours. 1. You may not have installed your printer in your PC. If so, insert the CD provided with your printer in the CD Rom. CD will autoplay. Choose the install or setup option than easy install option. Your printer will install and start to work. 2. If you have installed the printer but not print, you may not install it properly. Go to Add remove hardware in control panel. Uninstall your printer software from there. Restart your PC and after that install again as No.1 instruction. It will work. 3. If not print, change the USB port where you using the printer cable to another port. 4. If not change the printer cable which connect to the PC.
Hope above solutions can helpful to you.
Sep 02, 2011 | HP LASERJET P1005 Printer
I can not get the printer to print
I am assuming you are trying to print from a computer, not a photo memory card (SD Card).
Try the following things:
- get the manual and install CD if you have it
- use the manual or the menu on the printer to print a test page (if that works then it is probably not the printer)
- make sure the USB-B cable is connected
- Start the Print Manager software on your computer (install it from the CD if it is not installed already, download the drivers from on-line if you do not have the CD)
- Use the Print Manager to print a test page (If this works, then we know the cable works)
- in Control Panel under Printers select the Epson Stylus as the DEFAULT PRINTER
- from the application (MS Word, Photoshop, etc.) try printing and verify that the Epson is the selected printer
If this does not work please provide further details about what hardware and applications you are using and what you are trying to print.
Good luck. Bry
Jan 01, 2011 | Epson Stylus RX580 InkJet Photo Printer
How do i solve the printing ID problem of c5200
re install your printer...
install it in one of your network...
Feb 03, 2010 | OKI C5200n Laser Printer
Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Feb 21, 2009 | Epson Stylus R290 InkJet Printer
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
HP DeskJet 3745 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
