Question about Darda Toys
My daughter overwound a darda car
My daughter continued winding and winding the car, pressing it on the ground, in hopes of getting it to go faster, father. Something in it broke and not it won't wind to go at all.
  • 203 Answers
SOURCE: i have a humming noise in the engine of my 2001 Honda Civic EX.
sounds like either a belt or a bearing or both. joe
Posted on Nov 21, 2008
SOURCE: winding noise or vaccum leak from front of motor.
A/C -Heater controls
Has you are aware the A/C Clutch compressor is engaged at all times when the defrost mode is turned on. Turn off all heater controls. If the noise is gone it will be either the Air conditioner compressor clutch bearing or possible the idler pulley bearing .
The Warden
Posted on Apr 26, 2009
  • 436 Answers
SOURCE: Have a 'winding' noise that gets louder the faster
sounds like a wheel bearing they start to scrape and bind making loud noise while driving only. no noise while in park
Posted on Aug 24, 2009
  • 13 Answers
SOURCE: while driving the faster I go the louder the
My fan shroud was loose on my 2004 Sequoia and would vibrate. Faster I went, louder the vibration. Tightened it up and vibration went away.
Posted on Aug 31, 2009
ronald_kate_
  • 111 Answers
SOURCE: My DARDA upside down overpass track won't lie flat
I had the same problem with my sons track. An easy solution is to use a long thin piece of plywood and put adhesive velcro on the bottom of the track and the wood. This will keep it flat and can easaly be remove to put away.
Posted on Oct 29, 2009
Troubleshoot for my new england clock mantel,wind-up pendelum clock?
Your spring may have been overwound. There are several YouTube videos that show you how to release an over-tightened main spring.
Nov 28, 2017 | Home
I overwound my old travel alarm clock. Is there anyway to fix this on my own? I'm pretty handy with jewelers tools...
to unwind the clock, you need to open the winding spring.
Open the back, and there should be a part to move and unwind it.
Be careful to put the pieces in reverse order when you take it apart, so it will go together correctly I only say this because I've had to fix sewing machines that were not put together correctly..
Apr 10, 2013 | Audio Players & Recorders
Tissot prs 516 will not wind. doesnt work. Could it be overwound? I ride a motorcycle. Would the vibration overwind it?
This watch is described as "quartz chronograph", so it is not a self winding watch.
Go to http://www.tissot.ch/?mod_collections/action_getsubfamilies/colid_0002/famid_0012/refid_T044_417_27_031_00 for a description of the watch.
If it has stopped working, cold the battery be dead *have you had it for more than a year)?
Sep 28, 2010 | Tissot Prs516 T91141731 Watch
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
My daughters msi U100 won't boot up and it is in a
Switch off,hold down F3,switch on,follow onscreen instructions for how to repair,hope that helps.
Dec 05, 2009 | MSI Wind U100-030US Laptop
Continuous ground wire problem
What you do is to put a pigtail on each switch and use a wire nut/Scothlock to join to all the ground wires in the box.
Nov 15, 2009 | Lutron Toggler Single Pole 600 Watt Preset...
My DARDA upside down overpass track won't lie flat on the ground
Oct 29, 2009 | Darda Race Track Physics _
Trips breaker, windings not open, no continuity from windings to frame. startsfor split second then trips breaker. Breaker is ok
ASSUMING THIS IS SINGLE PHASE HAVE YOU CHECKED THE CAPACITORS. START CAPACITOR COULD BE BAD OR BURNT LEAD. HAVE YOU MADE SURE THE PUMP IS NOT LOCKING UP. POINTS IN THE PRESSURE SWITCH LOOK GOOD. HOPE THIS HELPS, JODY
Apr 26, 2009 | Plumbing
Train engine wont run
I made a mistake. My Train is not a Darda top train. Mine is a gp38 that wont run.
Jan 11, 2009 | Darda Lifelike Train Top
Not a problem but a question...might be a stupid one too. I just bought a new Bulova self winding BVA100 series watch. The instructions say to wind 6 times before using. I can understand why but the...
Your guess is right- watch is winding clockwise only. If you wind it anti-clockwise, the clutch weel gets disengaged and watch do not wind, so, you can do that as long as you like- nothing will happen and no harm to watch will be done.
6 times mean the movement of your thumb and forefinger with watch crown between them for 6 consecutive times. 2 times is as good as well.
And there will be no any clicks or sounds as the mainspring of watch is designed not to brake, but ease itself if overwound, so, no need for any alarming sounds.
Dec 01, 2008 | Watches
Toys Logo
27 people viewed this question
Top Darda Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Darda Toy Expert? Answer questions, earn points and help others
