Question about SHARP MX-3100N
Setting fax baud rate.
Need to slow fax transfer speed for Sharp MX-3100n with MX-FXX2 module.
nikeananth
  • 267 Answers
SOURCE: What is error code 5000 for sharp mx-3100n
HI,
this will help you out...
http://www.afoffice.com/sharperrorcodes.htm
thank you,
vijay(vote for me)
Posted on Sep 24, 2009
Testimonial: "Many thanks"
  • 3 Answers
SOURCE: Sharp MX 3100n showing code H5-01 , what is it,how
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Posted on Feb 20, 2010
  • 8 Answers
SOURCE: HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
just4fixya@gmail.com
Posted on Aug 17, 2010
  • 120 Answers
SOURCE: Our sharp MX-3100n printer is
Apparently your machine is set to stop when the supply counters trigger a maintenance code. You can type # * C * and go into Sim 26-38 and bypass this.
VC means your cyan developer has reached its' rated life of 60,000 copies and needs to be changed. Your yellow and magenta developer which are usually changed at the same time as the cyan have also reached their end of life (VM, VY) and so all 3 will need to be changed (not black, your VK code will come up at 100,000).
You will need the color developer kit and the seals and filter. Sim 24 resets the counters and sim 25 resets the toner-developer mix ratio (this is MANDATORY or your new developer will be ruined, you must run the copier with a door open and only close it when you are ready to set the mix).
There's also various color calibrations after this you can get from a service manual. DO NOT run old developer through your machine, it will eventually lose its' magnetic properties and be carried through the copier sandblasting everything in its' path.
Posted on Feb 24, 2011
  • 120 Answers
SOURCE: MX-3100N ERREURE C4:00
Your PTC- Primary Transfer Corona has gone out. This is an electrode on a stick located underneath the transfer belt on the right side. These are supposed to have a life rating of 300,000 but I have known some to go out prematurely. You can order the PTC seperately or with the 1st Transfer rebuild kit. Meanwhile, you can bypass the error by changing a soft switch.
From Copy mode type # * C * this will put your machine in service sim mode.
Type 55 - start then 1 - start
Set the engine soft switch 8-3 in SIM55-1 to "1".
This setting disables the PTC output, the heater
control, and the error detection.
After completion of repair, set the engine soft switch 8-3
in SIM55-1 to "0".
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
What is retry mode?
Retry mode is something the machine will do if you're faxing to a number that is busy, or to a number that the fax cannot immediately connect to.
Copier Collin Houston TX Copier and Imaging Expert
Aug 07, 2014 | SHARP MX-3100N
Sending a fax
You are doing it in the wrong order.
Press FAX. Load your document/s. Dial the number and press black start. It will take up to ten pages automatically That's it.
Jan 29, 2014 | Sharp MX-2600/MX-3100N Black Toner...
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
I have a sharp MX-3100N copier and need to fix the error C4-02
Your PTC unit needs to be replaced. Which is the Primary Transfer Charge unit.
Oct 31, 2011 | Sharp MX-3501N All-In-One Printer
I have muratec F65, i want to adjust the tx/rx baud rate to 9600, but in the setting i found nothing, pl guide ahmad dubai
Adjusting the Baud rate is something that a Serviceman has to do....there is no need tho'...your machine is smart enough that when "modem training" takes place each time you place a call..both the fax machines "talk" to each other and figure out how fast or slow they have to work depending on each of the fax machines and the condition of the line in between. They will slow down "if necessary" all by themselves.
Oct 29, 2010 | Muratec F65 Plain Paper Thermal transfer...
in SIM55-1 to "0".
Oct 23, 2010 | Sharp MX-3501N All-In-One Printer
Change baud rate on panafax uf880,885
That won't make any difference. ALL fax machines are ANALOG and won't work on a DIGITAL phone lines reliably
Nov 17, 2009 | Office Equipment & Supplies
Adjust baud rate on Sharp UX- 700 fax machine
It won't make any difference if you could. All fax machines are analog devices and won't work reliably on a digital phone line.
Nov 13, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
SHARP F0-4400 Need to lower baud rate to 9600 on
Don't do it, it will make your machine extremely unreliable.
Fax machines are ANALOG devices and will not work on a DIGITAL phone line.
Jun 26, 2009 | Sharp FO-4400 Fax
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
