Question about Kitchen Appliances - Others
My crust isnt dark enough
Time on the bread machine was a total of 3:10, and the crust was set for medium, however did not smell the aroma of the bread cooking and the crust isnt dark as I would like it.
    Genius:
  • 1,280 Answers
Change the crust selector to "Dark" on your next loaf
Posted on Jan 11, 2013
SOURCE: Hard crusts
I have an OSTER Breadmaker but if I wish a very light crust I simply turn the machine off 10-15 minutes early and leave the lid closed, which keeps the steam in and allows the crust to be softer. Then I have a new cold stick of margarine or butter, unwrapped part way, and slowly pass it over the top and sides of the new bread loaf. Sometimes due to weather changes or altitude we need to adjust our recipies, from those in our manuals. If your kitchen is 10-15 degrees warmer in the summer this can affect your machine. As with the amount of moisture in the air. My Gramma never made bread if it was rainy or a snow storm was brewing. The drop in air pressure made it uncertain if her bread would rise. Don't be afraid to fiddle with your recipe and adjust the amount of flour or kind of flour you use. Also have all ingredients at room temperature, for any recipe. Try various amounts of oil, water, an egg added, even if the recipe doesn't ask for one..! It is your bread and you get to eat it, it should be as you like it. The first adjustment is less time. Pull the plug early. Second would be the margarine. Third is play with the contents and adjust. Feed the birds the NOPES. Last reduce the amount of flour, but only by 3 tbsp at a time. This is the trick-y-est. Keep track on a paper and then re-write YOUR RECIPE on the inside front cover of your bread book.
Posted on Nov 21, 2008
JSEhandyman
  • 368 Answers
SOURCE: hard crust
Hello roszejon,
Dark crusts are usually a result of heat being too high, too long, and sometimes also a function of the chemistry of the bread. Since you're setting it on "light", either your breadmaker needs repair/recalibration, or there's something about the recipe. Odds are that the breadmaker needs repair.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: crust is always dark and hard no matter which setting I use
Just pull the plug on it when it has about 15 minutes left
Posted on Jul 13, 2009
  • 1244 Answers
SOURCE: never get a good loaf. Either bread doesn't rise
your not letting the yeast rise enough first sweety ! i used to have that same problem always let the yeast rise outside of the machine first!! then put it in there
Posted on Jan 14, 2010
SOURCE: Oster 5838 produces heavy loaves with heavy crust
Do not use room temp water as the instructions direct. Use very warm water.
Posted on Jan 24, 2010
Bread crust burns even on "Light" setting
Contact Oster for advice. Here is their contact info-
https://www.oster.com/contactus?cid=contact-us
Jul 28, 2015 | Oster 2 Lbs. Deluxe Bread & Dough Maker...
My bread always comes out looking to dark
Your oven is probably getting hotter than the thermostat you set it for reads. The outside of the bread is probably getting done too quickly and by the time the center is, the crust is dried out. Try a lower setting and see if it works. And you may have to adjust the timing. Sounds like your oven needs a new element maybe.
Feb 15, 2013 | Morphy Richards 48200 Instruction Manual
My panasonic SD 255 breadmaker, after quite a lot of use, is now baking bread with a harder crust than it did in its youth. We can get a softer crust by using the Sandwich loaf setting but then we can...
You never said if you remembered to select the LIGHT Crust setting each time. Did you? Are you? If you ARE using the LIGHT Crust setting and finished loaves are still too dark, I would have to say it's time for a replacement breadmaker. Nothing lasts forever my friend. Besides, it sounds like you got your money's worth anyway, right?
I've owned over 200 breadmaker myself so you can bet that what I'm saying is true. Sorry for the bad news friend.
Hope this helps!
Jun 15, 2011 | Panasonic SD-YD250 Bread Maker
WB 41055 is stuck in med crust color?
Hi, You have 2 choices to solve your problem. You can choose to repair or replace. The switch on the control panel is likely broken so you can attempt to repair it by taking it apart and replacing the crust selector switch or replacing the entire control panel. Control panel for various breadmakers can sometimes be found on ebay but they will be at least $20 once shipping is included. I am sorry to tell you the best choice is to replace your entire machine or just accept bread with a medium crust. Better to be stuck on medium that DARK. You can find new/almost new machines on ebay for abut $30-$40.
Jan 23, 2011 | West Bend 41051 Bread & Dough Maker
Can only use programmes which allow changing the crust setting to 'dark' other programmes half bake the bread.
This is a tough one. One thing you might try until you can replace your machine is to look in your manual and look at the page that shows the cycles of the program you chose. I wonder if you could shut the machine down after the last rise cycle next time,,,,,the,,,,. Push the Stop button until it beeps.... then unplug your machine and reprogram your breadmaker on the "Bake" program and set the time by pushing the timer advance button in 10 minute increments to the equivalent of the last bake cycle of your original program for light crust bread? That just might work!
Oct 22, 2010 | Panasonic Kitchen Appliances - Others
Lost my recipe book
Traditional White Bread (2 lb. loaf)
1 and 3/8 cups water
2 tblsp butter or marg.
1 and 3/4 tsp salt
4 cups bread flour
2 tblsp dry milk
2 tblsp sugar
2 and 1/4 tsp active dry yeast
Measure and add liquid ingredients to the bread pan
Measure and add dry ingredients (except yeast) to bread pan.
Use your finger to form a well (hole) in the flour where you will pour the yeast. Measure the yeast and carefully pour into the well.
Snap the baking pan into the breadmaker and close the lid.
Press "Select" button to choose the Basic setting.
Press the "Crust Color" button to choose light, medium or dark crust.
Press the "Start/Stop" button.
May 30, 2010 | Oster 5838 ExpressBake Bread Maker
Never get a good loaf. Either bread doesn't rise or crust is very dark even when on light setting
Jan 14, 2010 | Cuisinart CBK-200 Bread Maker
Need the operting Manual for PerfectBaker PB571
Here's some info;
http://www.creativehomemaking.com/download/TR888_1183_Recipe_Book.pdf
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Apr 25, 2009 | Breadman TR888 Corner Bakery Bread Maker
Hard crust
Hello roszejon,
Jon
Feb 11, 2009 | Welbilt Kitchen Appliances - Others
1st time w/ Cuisinart bread maker
There's a little arrow in the LCD screen that changes from 1, 1.5, and 2 lbs when you press loaf. There is also one for light, medium, and dark crust. Each time you press either button, the arrow will change which setting it's pointing to.
If you're using it in an area with low lighting, try using a flashlight (I have to do that on mine).
Jan 12, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
51 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
