Question about Archos 705 WiFi Portable Multimedia Player
705wifi will not record from TV
My Archos 705wifi will not record TV; it just freezes. It starts okay and the TV channel comes on the screen, but it just won't record. I've rest it and updated firnware, but to no avail. Any ideas anyone?
  • Hunicron Mar 15, 2009
    I have the same problem. I also tried to upgrade firmware, but newer dosn't exist. The device freezes as soon as I press the video recorder button or press the record button on the Headcam. I can see the video playing, but I can't record, quit etc...
Check your main unit clock and date setting. The recorder will not work if the date and time are wrong.
Posted on Jun 11, 2009
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
I am having trouble watching a recorded video on my tv
You need to insert a video-out cable in the headphone jack and press the TV button on top of the device. onnect the cable to the TV and the Archos screen should appear on the TV
Jun 17, 2010 | Archos 604 Digital Media Player
Tv program guide will not update when connected through my dvr
The TV Program Guide is actually controlled by a 3rd party.
I registered my Archos at Archos.com when I bought it......I'm not sure how you'd stand with a 2nd hand one.
Basically, the website tells me that I only have 82 days left to my TV Program Guide 'subscription' and if I want it for another year, I have to pay £14.90GBP!
However, I can tell you that the Program Guide is pretty rubbish. All it does is let you record the SAME channel that your TV is showing. It does not record a different channel if you want to watch something else and if the TV is switched off, it doesn't record at all!!
Reading the manuals and the reviews on the Archos website, I was led to believe that it would do all of the above, but when I tried to get help from Archos Support, they basically told me that it doesn't do any of that!!
As much as it p'd me off, that is the only flaw I have found in the Archos and the other things it can do are quite amazing.
Try searching for 'Archos Forum' and check out some of the features - it is a remarkable machine!
Apr 19, 2009 | Archos 605 WiFi Digital Media Player
hi i found my own soulution for recording i will tell you an easy way fist of all you need another freeview box only connect this to your archos and have the other box connected like normal to your tv and place your archos and other box near your tv buy a 2 way splitter from wilkinsons and connect this where your ariel box is probably near the window and get another tv lead to reach your freeview box for the archos this means you have a connection running from the tv box for your normal tv and f box and another for the archos and f box cos of the 2 way splitter you can then record on the archos from the f box and watch another channel on your tv then playback later what you recorded of your archos on your big tv please let me know if you sort this and let me no if you get stuck its great when you get it all set up and it works thanks.
Nov 09, 2008 | Archos 405 Digital Media Player
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
For some reason my archos 605 wi-fi will not record from tv. Has been okay since I bought it some 4 months ago. Comes up with corrupted file or similar thanks Jim
Thank you very much for your e-mail.
I have been in the habit of just suspending my Archos between use. Problem was solved by simply turning the Archos off completely. On switch on, recording worked perfectly.
Thankyou for your help
Jim
Aug 05, 2008 | Audio Players & Recorders
I cannot get my sons new Archos 605 to video from the tv. I feel like taking it back- what a waste of money!
I've had a similar problem. It finally started working though.....to a fashion.
I can now record the channel I am watching, but it does not record if the TV is switched off and I cannot get the scheduler to work at all.
When I first got mine 2 weeks ago, it would only record ITV, no matter what channel the TV was on.
Then on the 2nd day, it just seemed to kick in and whatever channel I put the TV on, the Archos displayed the corect channel.
Jul 28, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WiFi - 120GB TV guide problem
I had the same problem as you, after hours of browsing the frustrating archos website i simply deleted all the products from my account and then re-registered them. Turned out I'd simply put the serial number of my 605 incorrectly. Once re-registered, the tv-guide came up on my archos link software and updated it. Don't be too pleased though, when I did this about 98% of the channels just had "no information available" displayed on them on my Archos. Can anyone solve that?
Dec 27, 2007 | Archos 605 WiFi Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos 705 WiFi Portable Multimedia Player Logo
117 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
