Question about Ascaso ARC Dark Black Espresso Machine
Replace group head seal ascaso ARC - Ascaso ARC Dark Black Espresso Machine
  • Ascaso Expert
  • 54 Answers
Hi There, If you need a group gasket for the ascaso Arc
Try links below. If machine is the older model Ascaso gasket kit Dream Arc Basic If made after 2012 Ascaso group gasket Set 2012
Posted on Mar 16, 2017
2 Suggested Answers
  • 1618 Answers
SOURCE: have an Ascaso Arc Elipse - no longer heating the
Open machine and find reset thermostat, that may have tripped because of overheating.
Posted on Oct 07, 2009
My coffee maker stopped heating.
The heating element has burned out - it can be replaced relatively easy if you can get the part.
Jul 23, 2015 | Ascaso ARC Fun Espresso Machines - Black &...
Ascaso Dream
If your steam wand is leaking then you may need to replace steam wand o rings. These can be found at Ascaso gasket kit Dream Arc Basic . Available in a kit with easy to follow instructions.
Try Dream Arc Basic Ellipse 150 Products
Feb 16, 2014 | Ascaso Dream Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
My ascaso epresso machine does not heat water, I would like to buy parts for it.
We do not advise you attempt to install a new heating element in this machine. It is extremely meticulous work involving many small parts, you will need metric tools, meters, etc, it requires removing the old boiler, disassemble it, purchasing a new one with the correct gaskets and moving over all the sensors to the new boiler. We do this repair and even for us it is somewhat hairy.
Jan 05, 2011 | Ascaso Dream Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
Overheating ascaso dream, and too much steam
You need to descale the machine and replace the group spring valve. It is available in a kit . Ascaso Dream gasket kit versitale version There are a number ok kits for different machnes
Jan 02, 2009 | Ascaso Dream Espresso Machine
Ascaso ARC Dark Black Espresso Machine Logo
85 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
