Question about Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
Grohe ladylux leak - Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
SOURCE: Grohe Ladylux slow to turn off
Your Grohe Ladylux should be under warranty. Call the company at 630-582-7711. Their customer service was great when they replaced my quick coupling after it broke.
Good luck
Posted on Feb 24, 2009
megarza
  • 88 Answers
SOURCE: grohe ladylux cafe-no manual
hope this helps
Posted on Sep 30, 2009
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
  • 397 Answers
SOURCE: Water flow from grohe ladylux kitchen faucet has
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Posted on Jun 28, 2011
  • 92 Answers
SOURCE: grohe ladylux cafe kitchen faucet:
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Posted on Sep 07, 2011
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Good luck
Jan 14, 2009 | Grohe Plumbing
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
26 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
