Question about Philips DVP642 DVD Player
THE PLAYER DID NOT READ THE DISC IT SAYS" NO DISK"
THE PLAYER IS WORKING TO OPEN OR CLOSED THE DISC HOLDER . WHEN I PUT A CD OR DVD IT IS NOT WORKING . IT SAYS NO DISC, SO PLS HELP ME TO SOLVE THE PROBLEM
  • 3 more comments
  • strongmanfan Jan 20, 2009
    DVD player has played great up until today, load a disk and it reads,"no disk". only owned for maybe a year.
  • Anonymous Jan 27, 2009
    My system also seemed to be playing well, but then was nonresponsive, saying "open" when it wasn't opening and "load" when not loading. There is no sound, so clearly, nothing mechanical is moving. The system lights are all operating, but the tray is not and it is not playing. turning off doesn't seem to reset. I opened the unit and figured out how to extract the DVD, but didn't observe either a failed capacitor (the problem for the "blinking red light of no power") or a broken belt (a reason for the tray to not move).
    any other advice? Otherwise...recyling it will go.
  • SprksFam3 Jan 27, 2009
    We must have purchased players from the same lot. I have the same thing, player has worked fine (even earlier today), but now it won't load the disc. Sounds like it is trying to work, but then gives up and says "No Disc".
  • Anonymous Feb 16, 2009
  • Anonymous Apr 01, 2009
    I put the disc in, and it begins to read the disc for a second, then quits and says no disc. HELP!!!
    Problem Solver:
  • 6 Answers
Problem in the mother board
Posted on May 03, 2009
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
My media player does open and play in my Sattelite M200 laptop
You need to install the codecs,
visit www.free-codecs.com
and dowload from there, use the codec packs (xp codec pack or vista codec pack) I used both on my 2 laptops and they work fine.
May 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
DVD/CD disk drive keep rejecting
Sounds like it is not closing properly so the computer just opens it again ? if it is of the detachable type ( small release tag under computer marked with a closed or open lock icon next to release lever ) take out the drive with the door open it possible , check inside for any obstruction ( favorite place for children's random M&Ms ) if none visible check that the disk holder is below the carrige by using a small ruler place acroos the slide and see if the edges of the disc protrude above if not and you have found no foreign bodies in the drive replace the player into the machine .( I have found that occasionaly during manufacture the cariges are set a little high and as they wear they settle and they then catch on the center spindle ,gently easing the disc spindle holder down usually cures the problem .) There is I am afraid also a software glitch that causes this problem so if you have no joy with the first fix try uninstalling the drive from the Device manager and reinstalling on boot up . you do this by clicking on control panel .. then ... Device manager .. disk drives double click and the drives will appear select dvd and right click then uninstall .. for XP just go Control panel system device manager etc : reeboot and the computer will re install the DVD and hopefully clear the glitch .. hope this is of help to you Regards Vortash
May 14, 2009 | Lenovo ThinkPad T61 Notebook
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
DVD player and CD player stop reading discs.
try opening the Drive Trays, and hold a hot air dryer about 2-3 feet away for about 15-20 Minutes, Aim the dryer towards the opened trays. close the trays reboot the computer.
If still not working, i,d suggest putting a laser head cleaner in, and getting some more heat for your House.
Computers do usually tend to function much better at Room Temprature.
Hope this solves your problem.
Mike @ Compurepair.
Feb 22, 2008 | Televison & Video
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Won't open or load
I did fix it! The solution turned out to be pretty simple and easy!
Here is how:
1. open the box by unscrewing
2. rotate the multi-DVD holder counterclockwise (the problem was that the DVD spinner under the circuit plate was somehow stuck over the DVD holder)
3. you'll hear a click sound
4. turn it on and the problem solved!
rluo
May 31, 2007 | GE 5803P Multi-disc DVD Player
Philips DVP642 DVD Player Logo
240 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
