Question about LG Flatron 915FT 19" CRT Monitor
My monitor goes blank sometimes
Could it be going bad
    Scholar:
  • 52 Answers
It is possible depending on the age of the screen.
also check your cables and keep them clean.
Posted on Jan 19, 2009
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
My Acer x193w monitor is powered ON but goes blank
Is the display going dark, but if you shine a light on the display you can still faintly see an image? If that's the case, the monitor's backilight is going off. That's frequently because of capacitors that fail. You can open the monitor and check them, replacing any that are visibly bad or below their marked value.
If the display is going blank meaning there's no image but the backlight is still on, capacitors might still be to blame, but the might be other electronic parts at fault. The problem might also be in the cable. A bad wire or bent pin making a poor contact can cause the monitor to go blank. Examine the cable carefully or try another one if it plugs in at the monitor.
If the trouble's not something obvious and relatively simple, like the bad capacitors or a faulty cable, it's usually more economical to replace the monitor than to try fixing it. It's often hard to find service information for troubleshooting, and monitors are quite inexpensive now.
Hope this helps. Thanks for using Fixya!
Feb 26, 2010 | Acer X193W LCD Monitor
Lg w1934-bn blank screen after start up, power light on . same problem occurs on different computers used.
Reason 1: Wetness The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
i think this will help.
please rate my solution.
have a nice day.
Jul 05, 2009 | ViewSonic 17" 1280x1024 TFT-LCD/ Speaker...
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
try this.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor AOC 912Sw-4 does not turn on. Power button`s led is flashing all the time.At the beginning I waited some minutes and I could use it normally, but right now it is impossible see any image on it.
only choice is to give the monitor for service.
anyway read this, this help you.
Reason 1: Wetness
try this.
have a nice day.
Jul 05, 2009 | AOC 912SW-4 Monitor
Monitor is just not turning on
anyway read this.
this may help you.
reasons for why a monitor not turning on?
Reason 1: Wetness
try this.
have a nice day.
Jul 04, 2009 | Computers & Internet
Monitor goes blank after being on for a little bit.
A COMPONET INSIDE THE MONITOR IS SHORTING OUT TO THE FRAME OF THE MONITOR, OR YOU MAY HAVE A CAPICITOR GOING BAD INSIDE THE MONITOR, SO TO THE TV SHOP TO GET REPAIRED OR BUY A NEW ONE.
CANDYMANGANDY
Jan 29, 2009 | Dell Computers & Internet
Monitor goes black, with ghost lines of white. unplug and replug sometimes works sometimes does'nt. it's almost like it's burn out, or blown. pounding on the top works great, it comes right back on. this...
Its more or less your monitor has gone bad.
To check the same , unplug the monitor from the computer , a slef test feature check would be displayed . Check if the monitor goes blank or shows ghost lines . If yes the monitor is bad. If you have got the system before 12 Dec 2005 its generaly covered under 3 yrs warranty.If purchased after that , it would have your system warranty
Apr 20, 2008 | Dell Dimension 3000 PC Desktop
LG Flatron 915FT 19" CRT Monitor Logo
121 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
