Question about Canon PIXMA MX700 All-In-One InkJet Printer
Canon MX700 shows error 6480
The power light blinks, shows error, and unable to start it.
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
supersaiyan1
  • 5 Answers
SOURCE: Canon MX700 printer ink lamp fast blinking
1) Insert both ink cartridges and then check the ink levels that way it will tell you if there is something wrong with them.
2) Make sure you buy 1 colour ink and the other black and insert them into the correct slots.
3) Contact your printers manufacturer by going on there website. They may have a live chat.
4) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Posted on Nov 07, 2009
pineworks
  • 4041 Answers
SOURCE: When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Posted on Feb 16, 2010
    It was showing error code 5200, I did the fix of removing the print head and when I re-installed it , now it is showing that print head is incorrect. It is the original one that came with the printer and...
    1. The printer is turned off and plugged the power cord.
    2. Press Resume button 2 seconds
    then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
    3. Then release the RESUME button, but do not release the POWER button.
    4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
    5. Release both buttons simultaneously.
    6. Led will blink briefly and then will glow GREEN.
    7. And the computer will detect new hardware, just ignore ...
    8. Press the POWER button, then the printer will die.
    9. Press the POWER button again then the printer will flash
    Mar 17, 2011 | Canon PIXMA MX700 All-In-One InkJet...
    Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
    There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
    Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
    I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
    [6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
    May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
    PAPER JAM PROBLEM
    remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
    Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
    What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
    6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
    Thank you!
    Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
    My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
    According to Canon there is a way to reset the printer.
    Just go to this link and this should help.
    http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html
    If you need further assistace, please respond to this post and I will help you.
    Thanks for using FixYa
    asnowman
    Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
    When I start my canon pixma MX 700 series I gets error code 5100
    First of all, make sure you pay attention to when your warranty expires, because this error tends to repeat and you get disgusted and request warranty support only too late. The problem is probably caused by a sticky paper sensor, but the printer must be turned off and turned back on to reset. If it persists in displaying the error, then you should lift open the main part (scanner) look carefully in the back right for the black plastic piece that is the paper sensor and poke it with a narrow scissors or something to nudge it back down. Then turn it back on and hopefully it clears the error. However, if that's the problem then it will likely recur.
    Mar 14, 2009 | Canon MX700 Office All-In-One InkJet...
    Canon PIXMA MX700 All-In-One InkJet Printer Logo
    old marine
    old marine
