Why is JVC MX-S20 Stereo displaying "no disc" whenever I insert a perfectly readable cd?
It started by doing that only occasionally with burned CDs and it became systematic with any kind of CD to the point that it has not been able to play CDs at all in years.
SOURCE: mx-d402t jvc cd player - trays will not open
Just got one of these at the dump. Two problems quickly jumped out at me:
1. As mentioned above, the CD trays stuttered and clattered but would not open.
2. Volume control is unable to be reduced from the highest level (50).
CD tray table was an easy fix.
After removing the 8 cover screws (6 on the back and 2 on the sides) and the 6 tray mounting screws (two through the back and one in each corner) I unplugged the only electrical connector - it is a simple push in pull out type. Note the way it plugs in before pulling out - it doesn't matter which end which you unplug. I set the entire changing assembly aside (outside the tower) on a speaker - just for height because the cable is fairly short. Then hooked the electrical strip back up and turned the power on to the main unit. After setting the controls to CD and pushing the eject button for tray #1 it only took a gentle nudge of the linkage to allow the entire stack to free up. Cycled through the trays several times and each slip in and out as designed.
The next step is not for the faint of heart. Since something (in this case just some cat hair and normal 10 years of dust) was causing the trays to stick it was decided that the entire unit should be thoroughly cleaned. With most electronic devices as long as there is no power on the component it is perfectly okay to wash the entire unit with hot (really hot) water from your kitchen sink. A soft tooth brush and some liquid detergent help the process. After a good long wash and rinse, gently shake as much excess water from the piece and find a supply of warm flowing air. Set the component in front of the air supply and allow it to dry for a looong looong time. 3-4 hours is good.
Hook it back up, cycle the trays and observe the function, paying special attention to where the moving parts make contact. Then shut it down (or not depending on your confidence in your hands) and apply some WD-40 to a q-tip. Using the swab apply a small (the key word is small - you do not want oil based liquids to get anywhere near the CD reading LED) amount of lubricant to the previously observed bearing points. This procedure is best accomplished as the linkages are moving throughout their entire stroke but be careful to not catch the swab in the moving parts.
Now (while I wait for my C changer to dry out), I will trouble shoot the volume problem. If it is something that can be fixed, I will update this post. Please don't assume that just because something has some years on it that one should "expect" it to fail. Oftentimes it just needssome TLC.
Posted on Nov 24, 2008
  • 78 Answers
SOURCE: CD WONT PLAY
It sounds like it is attempting to read the t.o.c. (table of contents) which tell the unit where everything is on the cd,and failing to do so, then ejecting, the first thing to do is try cleaning the lens and if there is no change then replace the laser pickup
Posted on Nov 21, 2007
  • 319 Answers
SOURCE: cd player will not read disc
Unit probably has defective disk motor or function sensor
Posted on May 08, 2008
SOURCE: Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
Posted on Jul 09, 2008
rscheutz
  • 54 Answers
SOURCE: RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Posted on Mar 22, 2009
Cd inserted in cd player no disc
The problem is in the laser pickup assembly, overtime the laser becomes weak until it will no longer read the disc, it is far cheaper to replace the stereo than have the old unit repaired.
May 01, 2012 | JVC MX-GT80 Shelf System
Jvc kd hdrc60 please eject disc
CD mechanism probably needs service.
Feb 22, 2012 | JVC Car Audio & Video
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
MY UNIT WONT PLAY CD'S
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
I have discs in my cd player but it says NO DISC.
The "no disc" messing indicates that the disc is not readable. This can be due to a dirty lens on the optics or defective optics. If you can gain access to the CD section, try cleaning off the lens of the optics assembly using a cotton swab and alcohol. Let me know if that does not resolve the problem.
Dan
Dec 02, 2008 | JVC MX-J10 Shelf System
RCA RS1285 No Disc message
you can get lens cleaner cds that have little  brushes on them
Nov 01, 2008 | JVC MX-K30 CD Shelf System
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Sep 22, 2007 | JVC MX-KB30 CD Shelf System
 Grubhead
Grubhead
