Question about Bunn CWTF 15-APS Coffee Maker
Water leaking out of front of bunn cwtf 15-aps coffee maker
This is brand new and just connected to water line so testing to make sure water volume is good but water is leaking out of the front
  • 60 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
EsWorld
  • 1618 Answers
SOURCE: Bunn CWTF 15 Coffee Maker Overflowing drastically
Have you tried resetting the brew volume(make sure board is not set to lock).
The only other thing I can think of is replacing the timer board, because its not telling the solenoid to stop brewing.
Posted on Apr 28, 2009
EsWorld
  • 1618 Answers
SOURCE: installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Posted on May 04, 2010
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Bunn cwtf adjust temperature
u must locate the lock bottom to open and re- programs ur temp. settings...
Jun 27, 2014 | Bunn CWTF 15-APS Coffee Maker
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Water not coming out of hot water spigot
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
Water leaking from the top
open up the top and check the trough drain for lime. if it is obstructed, the water will overflow. use a screwdriver and poke it through the drain
Nov 07, 2013 | Bunn CWTF 15-APS Coffee Maker
Bunn coffee maker cwtf15 water is boiling over
if it's actually boiling, replace the high temp limit fuse on the top of the tank on the inside rear of the brewer. may be stuck shut. if it's just overflowing the container, recallibrate by using a 64 ounce measuring cup and the instruction on the inside of the front panel
Oct 02, 2013 | Bunn CWTF 15-APS Coffee Maker
Water not getting hot anymore
by 'reset' do you mean that you moved it, tilted it, shut it off and back on?
Mar 06, 2013 | Bunn CWTF 15-APS Coffee Maker
My Bunn CWT15-APS , PF works well except when i push the start button it only makes a few ounces of coffee. Can you help?
It is possible that the brew volume needs to be set, remove the front panel and you find the instructions to set the brew volume.
Sep 22, 2011 | Bunn CWTF 15-APS Coffee Maker
I have a used Bunn CWTF15-APS, that warms the water but does not heat all the way up. I'm wondering what is causing this problem. thanks so much
I would remove the front panel and check the pressure stat to make sure it is set high, turn knob all the way to the right the back it up 1/4 of a turn. It that is done and after 7 minutes water is not hotter then the problem is on the top, the hi-limit needs to be replaced.
Aug 19, 2011 | Bunn CWTF 15-APS Coffee Maker
Cwtf is a contant dripping from the dispenser funnel, how do i fix this?
Inlet valve is leaking.Valve is located by removing front access panel.Can be rebuilt using p.n. 1111.0002 repair kit.You can verify by removing top lid and finding water leaking at fill basin tube.
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
Apr 26, 2009 | Bunn CWTF 15-TS Coffee Maker
Bunn CWTF 15-APS Coffee Maker Logo
90 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
