Question about Dishwashers
Frigidaire Dishwasher has no power
Frigidaire AquaSurge with Speed Clean
Model No FDBB4365FC0
14 months old, warranty expired
checked that power is available a socket
stopped working, ie wouldn't turn on
no lights, no error message
  • lisadon May 09, 2009
    Same thing. Just not turning on. Owned for 15 months. No warranty.
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
rhinostack
SOURCE: whirlpool quiet partner III clean light blinking green
press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done. open and close the door and make sure it is closed.
Then run another cycle. saw this on another post and it worked for me. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
---Rhino---
Posted on Dec 22, 2008
SOURCE: Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Posted on Feb 22, 2009
SOURCE: our 6 month old frigidaire
My unit has the same problem and it is due to a failure of the control board. The tech that came to look at it tells me that this unit vents from the top of the tub rather than from the front, and he claims that the installation instructions require a 1" gap between the top of the tub and the countertop.
Now I have found no such information in the installation manual that I downloaded, and I am skeptical that a 1" gap could be done, and if it could it wouldn't look to good.
I am going to pull my unit out and see exactly where the vent fan is and what the clearance is. The service tech says they can't replace the control panel until the installation is proper. I am thinking this is at least to some extent a design flaw with this machine. There seem to be a lot of reports of this failure.
Posted on Apr 08, 2009
Krazytech
  • 725 Answers
SOURCE: ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
My frigidaire professional series aquasurge won't start
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# PLD3465REC, will not start. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire dishwasher shuts off mid cycle
Hello - From what you are describing it appears that the unit is attempting to run the cycle, but the wash motor is not coming on. Either the wash motor has failed or there isn't any or isn't enough power supplied to the wash motor. I personally recommend contacting a service provider to accurately diagnosis the dishwasher and to assist with the repairs.
Feb 22, 2013 | Frigidaire Gallery FGHD2433KW Fully...
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
Our 14 month old dishwasher will not turn on
if you are getting no lights on the display and assuming you have mains power getting into the dishwasher, the problem could be on the power control board located at the top part of the door module under the display panel.
Refer the control panel diagram item K253
You have to be careful when handling the dishwasher. Make sure it is disconnected from the main power and the water inlet is turned off. If in doubt call the service technician. You are still covered by parts warranty for 2-5 years (depending on part) See warranty policy in operators manual
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
Frigidaire Aquasurge, panel is flashing, cannot
You might remove the front panel (screws on the sides) pop off the front plate, and remove the fuse. Put it back in after 5 minutes... sometime this fixes it
May 13, 2010 | Dishwashers
I have the 4000 Series AquaSurge with speed clean Professional series. I have a white film on the dishwasher and all dishes, glasses and silverware. The right bottom of the door always has a leak about...
With regards to the white film, I would check for a soap buildup. Turn the dishwasher on, let it run for 5 minutes or so then open the door and see if there is suds. If there is, pour a half cup of cooking oil in the water and let it finish the cycle. That will clear the suds. It is possible that the rinse agent dispener has failed and is letting in too much jetdry as well. With regards to the leak, install a slash shield in the gasket, part number 154701001. it comes with instructions, really easy to put in and should fix teh problem.
Mar 26, 2010 | Frigidaire Dishwashers
I would suspect a faulty touchpad/console. They get moisture in them and short out causing all sorts of problems.
Mar 23, 2010 | Frigidaire Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwashers Logo
187 people viewed this question
Top Dishwashers Experts
