Question about LG 32LG40 32 in. LCD HDTV
MY LG 32LG40 BUILT IN DVD KEEPS SAYING NO SIGNAL AND WON'T ALLOW ME TO PLAY DVDS. WHAT CAN I DO?
  • 1 more comment
  • jennihinyofa Feb 10, 2009
    I am having the exact same problem. It just occurred out of nowhere. have owned TV for about two months now, bought totally new from best buy.
  • Litlrox Feb 10, 2009
    I had a similar problems as well and I bought mine around December and it is acting real weird. I put in a DVD it sucks it in, ejects, plays...pause ejects..and so forth. And when I am not even in DVD area, I am on AV2, it says "No disc" and you hear a noise like it is trying to take in a disc. This is just driving me crazy. I tried to unplug the back and stick in more...for some reason it doesn't want to go all the way. I shuved the cable in the back and so far, it is ok. But I will not hold my breath on it. I wish I should have gotten just a regular TV without the DVD player. :-( This TV has a nasty memory that remembers everything that you clicked on.
  • tdf520 Mar 09, 2009
    That was the cure. It absolutely worked. The only problem I got is, why doesn't the manufacturer put this in troubleshooting.
Hold the power button on the front of the set down for 5 seconds and then unplug the tv while continuing to hold the power button down for twenty more seconds then plug tv back in this resets it and it should work. It worked for mine when I called the service center at LG.
Posted on Mar 07, 2009
Hey thank you all.. so glad I found this site, I wouldve thought the DVD player was defective and since no more Circuit City.. what a drag it would've been to try and get service help!
Posted on Apr 12, 2010
I have an LG LCD TV/DVD Combo 32LG40 that is a 1 1/2 old. When I insert a dvd, it says loadingf for about 2 minutes then says disk error. It does this for all dvds yet the dvds workk on other players. ...
Hi, sounds like the laser pickup (module) is faulty and needs replacing, you'd have to take it in for repair or if you are able to repair it yourself make a note of the laser pickup number (usually on the side of the pickup) you may need a magnifing glass to read it then search google for it, they are usually pretty easy to get, if not contact your local repair shop, they may be good enough to order one for you,
Hope this helps.
Feb 11, 2011 | LG 32LG40 32 in. LCD HDTV
LG model 32LG40 /w DVD player; disc stuck inside; cannot remove or play disc.
You must take your set in to have the player removed, dis-mantled and the disc removed. I never recommend to my customers ever buying a built in unit. Just food for thought the next time you purchase a set. Always buy separate.
Nov 26, 2010 | LG 32LG40 32 in. LCD HDTV
I have an LG TV/DVD Combo 32lg40. The DVD drive will not allow me to load dvd's how do I fix the dvd player on this TV
I have had this problem. Unplugging the unit from the power source for 5 minutes and plugging back in solved the problems. This has happend twice in 1 year.
Mar 19, 2010 | LG 32LG40 32 in. LCD HDTV
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
Need unlock code for TV/DVD player 32LG40
Presiona el boton de MENU en el control remoto y al mismo tiempo el de MENU en la TV, por unos 10 segundos, aparecera el password que de fabrica es "0000" despues entras a un menu y hasta abajo, creo que es la opcion 8 aparece cambiar la region del DVD, ponlo en WORLWIDE y podras ver cualquiere region
Apr 08, 2009 | LG 32LG40 32 in. LCD HDTV
32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Mar 24, 2009 | LG 32LG40 32 in. LCD HDTV
32lg40 with dvd - how can I watch avi. movies?
NO,,,,BUT IF YOU HAVE A PROGRAM U CAN,,,GET CONVERTING PROGRAM OFFLINE,,, CHANGE THEM ,,THEN ITLL WORK ON ANYTHING
Mar 14, 2009 | LG 32LG40 32 in. LCD HDTV
LG service centre in mumbai
I have an LG DVD Recorder Model DR 389. It first stopped recording (was getting message "regional code incorrect" & was playing DVDs. Now when a recorded or pre-recorded DVD is put in - it just keeps saying "Reading" .... and doesn't play.
Could it be the lens ?
Jul 29, 2008 | Televison & Video
LG 32LG40 32 in. LCD HDTV Logo
3,176 people viewed this question
Computer Repairing
Computer Repairing
