FixYa.com
Tags:
Datamax M-4208 Thermal Label Printer
4208 Datamax M Class printer Problems
posted by PrintCrazed on Jun 27, 2007
I am having trouble when i changed the size of my labels the printer light is blinking ERROR. The on the printer screen is says position fault?????? What is wrong with this stupid thing?????
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 21, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
After changing the size of your labels the printer needs to measure the new label length. Press the feed button for four seconds (wiht new labels loaded & printhead locked down). If this doesn't fix your problem you need to correctly position the media sensor.Make sure the short white line on the media sensor is above the label gap.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 24, 2008
Not Rated (0)
neviknworb
Rating: 0%, 0 votes
Check inside the green guide (sensor) for pieces of label. That will block the sensor. If the sensor is reporting a thickness which is double (250) what you expect, then that is definitely the issue.
Can you Help with these Printers problems?
Printers
hi i have mislaid my
hi i have mislaid my lead that... Answer This...
fault problems
top form fault, and position... Answer This...
All lights flashing
This is a fairly new Datamax... Answer This...
Datamax printer code
send Dpl code to a datamax... Answer This...
Datamax I-4208 Thermal Printer.
I'm trying to install a... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
