My sansui sw 6000 subwoofer amp power indicator light not switching on. checked fuse and power supply. ok. what could be other problem.
My Sansui model hdlcd3700 has sound but no picture at the power on, the back light flashes once. my question is power supply or or inverter?
first of all you have to check the power supply. sometimes bad electrolytic capacitors on the power supply can lead to such problems. may the capacitors seems ok visually but not be good in performance. if power supply is ok then you have to go for a ne inverter board. check the video to understand how to check the power supply of lcd tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 11, 2015 | Sansui Televison & Video
I have lost both front right and rear right lights on my peugeot 307 SW 2005
Check ground and 12v supply for all the affected bulbs. Check fuse with proper test light. Is there a separate relay for right and left lights?
If there is, try switching them.
Feb 19, 2014 | 2005 Peugeot 307 HDi
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to...
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Dec 31, 2010 | Sansui RZ-5200AV Receiver
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
Indicators keep blowing fuses Hazards ok
THE WIRES ARE NORMALLY PUSH ON LIKE SPEAKER WIRES BUT IF IT IS MELTED THERE IS A SHORT IN THE WIRE SOMEWHERE IT COMES OUT OF FUSE BOX THEN TO RELAY UNIT THEN FROM RELAY TO SWITCH THE RELAY MIGHT BE FAULTY CAUSING WIRES TO HEAT UP RELAYS ARE LOCATED IN FUSE BOX THERE IS ALWAYS MORE THAN ONE SO SWAP FOR ANOTHER RELAY REPLACE FUSE AND TRY LIGHTS AGAIN TO SEE IF THE RELAY IS THE PROBLEM HOPE THIS HELPS GLENN
Nov 14, 2008 | 1999 Isuzu Trooper
110 people viewed this question
 Grubhead
Grubhead
