Hoover Windtunnel Supreme U5280-900 Upright Vacuum
Problem for Hoover Windtunnel Supreme U5280-900 Upright Vacuum
Installing belt
By floyd27165 on Jan 19, 2009
How to install a belt on Hoover upright vacuum
Best Solution
posted on Jan 20, 2009
Helpful)
chris321918
Rank: Wiz
Rating: 89%, 17 votes
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Hoover Windtunnel Supreme
Questions and Unsolved Problems for Hoover Windtunnel Supreme
Do you recommend Hoover Windtunnel Supreme U5280-900 Upright Vacuum?
Answer
Answer
The thing is not sucking, but when I look inside where the bag is the bag seems to be being sucked... (More)
Answer
the exhaust air coming thru the side filter seems very warm. I would guess 85-90+ degrees or more. ... (More)
Answer
Dirt sensor on my hoover supreme remains remains on red all the time
Answer
i need to change the belt on a hoover upright vacuum model number u5057-930
Answer
I need to remove the agitator from upright washing machine. it is a 2325L. my question is what size... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
in , AR
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
