WTW4840YW unit fills & empties without washing and spinning. Even after reset - sometimes it works sometimes not. Can you help?
WhIzAtIt
  • 136 Answers
SOURCE: washing machine won't spin
The lid switch is likely defective. Test with a VOM meter and replace as needed.
Posted on Sep 21, 2007
  • 209 Answers
SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Posted on Oct 10, 2007
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Posted on Nov 24, 2007
  • 1294 Answers
SOURCE: SIEMENS WXLM112GB FRONT LOAD WASHING MACHINE
Perhaps the exit hose behind your machine is not at the correct height, about 3 feet from ground. Your pump pumps the waste over this height, into your standpipe or sink; check this out.
Posted on Feb 13, 2008
SOURCE: washing machine will not empty or spin out
washing machine will not get empty or spin out
Posted on Sep 15, 2009
Asko 10505 Washer will drain but will not spin. Initially that was the problem, but then in trying it out again the washer will fill with water, will drain but will not even wash now. Do you think it is...
You don't mention if the drum spins if you choose the spin program, if it doesn't it could be the brushes on the motor. This would be a cheaper option to try first rather than a board. sometimes you can clean the com or tap the brush carriers gently and get the motor to spin on an empty or small load.
If you're confident, with the power offer and machine isolated you can check the resistance across both the brushes and slowly rotate the motor as a test.
hope this helps
Mar 12, 2013 | Asko Washing Machines
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Will wash but not empty nor rinse nor spin but will only fill and wash
You have a bad lid switch, the unit will not progress through the cycle without sensing the lid is closed. With a model number I can help you get to the lid switch and or replace the switch you need.
Hope this helps
Jul 13, 2011 | Roper Washing Machines
First washer would not fill tried later it started got to spin stop will not empty water tried drain and spin button still wont run help thank you happy hoildays joe thomas
Suds detection & long drain error codes indicate a problem with the water draining out or too much soap is being used. If the unit is not draining good then I would suspect a problem with the pump or control board. Please see the images provided for more details. Press stop twice to reset the control.
Dec 17, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills up then nothing else happens will not wash or spin it will fill and empty
if u hear the motor running after it fills then u need a motor coupling
Jul 21, 2009 | Kenmore 44072 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine won't spin
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Jan 28, 2009 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
