Can not get A.M. reception on a stereo in a hot tub. F.M. comes in fine.
  • 119 Answers
Am is a signal sometimes you can and sometimes you can't, all you can do is select the am station you want, move the radio around till you get the station and don't move anymore
Posted on Feb 25, 2009
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Oct 09, 2010 | JBL Marine Audio Wired Remote
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
I purchased a Catalina Hot Tub that has a KDC-MP228 installed. The radio works however the CD player does count, recognizing the disc however there is no audio coming from the pop up speakers located on...
It sounds like the stereo has got some faulty circuitry internally. You'll need to replace the unit to be able to listen to CDs in your hot tub. you may want to look into getting a marine radio as a replacement. I'm sure this will be more suited to this application and is probably the kind that should have come with the tub in the first place. I hope this helps and good luck!
Feb 17, 2010 | Kenwood KDC-MP228 CD Player
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Radio has no reception
Stupid question , but check if antenna has come loose if not then you have internal problems
Apr 21, 2009 | Sony Xplod CD Player w/MP3 Playback...
Radio Problem
There is not an easy answer for this one. Some troubleshooting needs to be done. I have seen the Rockford Fosgate system in many of the newer Sentra's. Try hooking a known working speaker to a nonworking position. This will tell if it is a speaker problem. If the problem persists, this could be stereo or amplifier.
Terrible reception troubleshooting, a bad antenna will give poor FM and no AM. If both have bad reception, this is a stereo problem. You can remove the stereo from the dash, place a small pick tool or screwdriver into the antenna jack and test reception. If the reception problem clears, this is a antenna problem. I have seen car detailers pull the connector from the rear window antenna and forget to plug it back in too.
Nov 10, 2008 | Car Audio & Video
Reception
Inside the car there should be a splitter between the stereo itself and the antenna in a side plate
behind the dooor kind of under the dash follow your antenna wire from the stereo you should find the splitter along the way it may have came loose or even off
Apr 23, 2008 | JVC KD-G720 CD Player
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
 Grubhead
Grubhead
