Question about Lucent PARTNER18 Corded Phone
AUTO ATTENDANT NOT ANSWERING
MY AUTO ATTENDANT IS NOT ANSWERING - GOES RIGHT TO LIVE RECEPTIONIST WHEN CALLERS CALL IN. WANT THE AUTO ATTENDANT TO PICK UP. HAVE LUCENT PARTNER 18D PHONE. THANKS...............................PARTNER MAIL VS
  • 27 Answers
There is about three to four programs that need to be set up in your phone system in order to do this , the program number my be a little different depending on the partner system you have .
Posted on Feb 27, 2009
I have Partner mail vs release 5. When someone calls in they get the receptionist voice mail(10) instead of the day menu prompt of the automated attendant. How do I get messages to go to the automated...
You are going to need to get into programming.
#206 group 7, line 01, change from "3" to 2 assigned
You need to do that for all lines. That will make it go to the Auto attendant instead of the mailbox.
Jul 16, 2010 | Avaya Lucent Partner 616 Phone
My customer has a Partner Mail VS 4.0. At times
Never heard that one before, you might try # 306 and see if the return extension is itsself.
Apr 16, 2010 | Comdial Avaya Partner ACS Phone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
Help answering calls during peak call times
Yes you need the PC ASA card and not ASX,
Example: to speak to a live person dial 72 and the zero time out option sends it back to reception and it will place it on hold,
reception would need to activate a programmable button ASA button when experiencing high volume calls,
If nobody picks up it will revert to the reception or zero time out attendant with another greeting depending on what type of avaya voice mail you have?
If you have R5 vs mail or Partner mail and not a PC mail some tricks can be done.
This may not solve your answer and ring delay on day or night mode needs to be looked at.
The reality is you can delay the callers ability to get to a live person for a minute or so if they choose to hang out without a ASA card.
Send them to an unused ex port and assign the port to automated attendant two. Depending on you VM we can have up to 5 AA's and greetings.
The fact is if your receptionist can't place the call on hold with a music on hold greeting that says's Bla Bla Bla and more nice stuff and stay on the line we will be with you shortly then you need to hire a new receptionist.
Aug 08, 2009 | Avaya Lucent Partner 616 Phone
Direct dialing
I'm almost positive that what you are talking about is called an "Auto Attendant" or "Automated Attendant" which is a feature that is built in to most Voicemail cards, (e.g. IVP8, Stratagy DK, ies16, etc.). If you don't have a voicemail card, you need to get one for this feature to work. You also may have to have a technician set up your voicemail card to have the auto attendant feature on, or you can do it yourself, if you know how to. if you aren't really sure how to do it yourself, I wouldn't take a chance as you may mess up your system.
Hope I was able to help!
Jun 07, 2009 | Toshiba DKT3010SD Corded Phone
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Auto Attendant
You are trying to access the admin mailbox for a newer voicemail than your system supports.
After dialing intercom777, try 99# and 1234#.
That will get you into the voicemail, and it will tell you the release (Partner mail VS rel 4, 5, etc...)
Need to know that for further instructions.
Jul 22, 2008 | Lands Phones
Lucent PARTNER18 Corded Phone Logo
725 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
