My washing fills.,then does a short spin then tries to fill again. it does'nt actually empty during the spin. '
  • 90 Answers
It sounds like the water emptying sensor is bad and needs replaced.
Posted on Jan 19, 2009
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Hoover se147 washing machine fills with water then trips electricty
it has a short in it,could be the drain pump,or the wash motor or a bad fill vavle
Nov 10, 2014 | Washing Machines
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
.My LG washing machine fills
If it fills and empties, that Eliminates The Pump. If no Spin Of the Actual drum, Could Be Belt-Stretched/Snapped. Motor brushes Worn. Or A Problem With the logic board Controller Panel.
Go for The belt/Motor brushes first.
Mike.
Jun 02, 2011 | LG Washing Machines
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Whirlpool will fill, starts to spin, and empties water - then it starts to fill again and repeat the spin and emptying again.The only time it does not do this is if only the spin cycle is used.
That sounds like a defective controller unit. Go to: SearsPartsDirect.com They have break-out drawings that list each replaceable part and number.
Nov 09, 2009 | Kenmore 22422 Top Load Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
