Question about GE JES1039 Microwave Oven
GE Profile Spacemaker Microwave - JVM1660BBC
The turntable either just barely turns or doesn't rotate at all. Any ideas from anyone ? Thanks.
  • 1 more comment
  • Nlc Christ Jun 27, 2007
    Thanks for the help so far. I really appreciate it.
    So I tried something else...if I remove the glass plate, put a cup of water in the microwave and turn it on, then the plastic spindle moves, no problem. When I put the glass plate back on, it rotated, no problem. When I put something on the glass plate, like a coffee cup with water, it barely turns and then stops.
  • Anonymous Jun 05, 2008
    how to replace motor
  • Anonymous Mar 23, 2014
    TURNTABLE WON'T ROTATE
  • GE Master
  • 9,125 Answers
Either the turntable motor is weak or the coupler has cracked or worn out.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
FYI, the high voltage is only 3-4000VDC but still quite lethal.
Otherwise, the previous solution is accurate.
Posted on Nov 26, 2007
  • William Miller
    William Miller Nov 26, 2007
    We're happy to help and we appreciate your thoughtful rating of our answer.
  • 5,911 Answers
The turntable has a small motor underneath it that rotates the glass tray. You could have a motor that is going bad, or the plastic spindle (what the glass plate sits on) could be slipping. You can access the motor through the bottom panel. Be careful to make sure the microwave is unplugged for attempting any repairs inside. There is potentially as much as 14,000 volts in the high voltage network around the magnetron. Let me know if this helps.
Posted on Jun 27, 2007
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Turntable in GE Spacemaker does not work most times. If rotate manually, may work for a moment -- but won't stay on.
I think you have the worm gear worn. Even the motter is okay. It comes with all things together, so just replace the moter .
Thanks
Please rate me
Nov 13, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
GE PROFILE SPACEMAKER MODEL JVM1350BW
There is a turntable motor that maybe bad you can access it by removing the scres on the boyyom of the uniot it will flip down on a hinge NOTE: you do not have to take down the microwave to do this. the motor should be getting 110v when on also make sure on your keypad it says Turntable on Some models have an option to turn it off on the keypad
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1039 Microwave Oven Logo
304 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
