Question about Kenmore 22422 Top Load Washer
My washer is not spinning.
It has power to it, the water does disperse into tank and it eventuallyl releases the water, but the bowl will not spin at any cycle.
  • benfamily7 Jan 19, 2009
    I will certainly look into that website. I will also get back to you if the problem is solved, thanks again.
    President:
  • 1,214 Answers
Sounds like the gearbox may have stripped out if it pumps the water out (motor is good as the same motor is used for the pump and the gearbox, pump on one end, gearbox on the other, of the motor.).
Go to Sears Parts Direct and type 110.22422 for the Model number, look at the exploded view for the agitator.
Posted on Jan 19, 2009
  • Mark Egan Jan 19, 2009
    You might also check whether the agitator has stripped out on the splined drive shaft.
    You do this by removing the cap, then the bolt, on the top of the agitator, inside the lid of the washing machine.
My WL80t65C has had the RPS replaced, now won't spin the Bowl, does first stage of wash cycle then does not spin the Bowl. Times out. Code 40! Any ideas?
Fisher Paykel Top-Load Washer WL80t65C Error 40
Error Fault Condition
- Spin Basket Will Not Engage Or Disengage From Clutch.
Repair or Check - The spin basket has to be able to rise and fall with the water level. This is to engage and disengage from the clutch. Unplug the washer from power. Remove the spin basket. Remove any objects found between the spin basket and the tub. An object could be interfering with the spin basket clutch engagement. Replace any broken drive components.
Parts for Replacement - Drive Components.
Sep 20, 2016 | Washing Machines
No spin
Is there water in bowl? If So then check the drain pump for blockages or not running. The spin will not start if there is water in the bowl
Jan 23, 2014 | Maytag NFW7200TW Front Load Washer
Washer dont spin out clothing
Is all the water pumped out of bowl.
If all water is pumped out, try blowing air down the clear pressure
tube to dislodge any blockages that would stop the bowl from spinning.
Jan 02, 2014 | Fisher and Paykel IWL12 Top Load Washer
LOAD TOO WET AFTER SPIN CYCLE
  • NOT DRAINING PROPERLY
  • spin bowl not turning
  • spin bowl slipping and not gaining proper speed
  • pump blocked
  • pump not working
  • too much soap used
  • take out pump and check all the water ways
  • observe the spin bowl turning
  • Next call for pro help
Apr 01, 2011 | Kenmore 23822 Top Load Washer
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
SPIN CYCLE- NOT SPINNING
Sounds like the lid switch is broken if it won't spin OR drain. Find hole under lid and push pen on plastic flap. If the plastic is not there or doesnt' "click" when you push it, there's the problem.
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine stops at spin cycle and now won't run at all
Possibly the lid switch. It won't spin if it doesn't know the lid is closed. Some washers won't agitate with the lid open either, so let it fill until it starts agitating, then lift the lid. If the washer stops you know you've got a good lid switch. If it keeps going you know you need to test the lid switch. Just hearing if it clicks or not is not always a sign it's good. Some Maytag/ Admiral washer lid switches have more than one contact that must close to spin.
It could also be a problem with the timer. Put it in the spin cycle where you know it should be spinning. Make sure the lid is closed. Grab the timer knob and try wiggling the timer shaft up and down and around without turning the knob. If it starts and stops you've got a bad timer. You may still have a bad timer if nothing happens, but you'd have to check it with a meter.
Jul 21, 2008 | Admiral AW22 Top Load Washer
Washer Will Not Hold Water
What height is mentioned in your manual for your drain pipe (the outlet pipe for your machine) There should be a height (before u bend it downwards into the drain) or the water will just flow out........... And do not over-load your washer.
Apr 24, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 22422 Top Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Robert Rankin
