Question about HP W1707 LCD Monitor
My monitor is telling me to change the resolution to 1440-900 but my control panel and NIVIDA programs dont have it as an option. My it goes from 1360 768 and skips to 1600-1200. How do i get it to 1440-900. Thanks
    Scholar:
  • 52 Answers
In your nvidia control panel on the top set it to advanced settings.
then in the menu on the left there should be a option called : Manage custom resolutions
in there you just click create and enter the values you want.
if the option is not in the menu try updating your video card drivers.
Posted on Jan 19, 2009
How to change monitor resolution
You change the resolution using your windows operating system.
If you are using a window computer press the start Button lower left end corner of your monitor screen and select control panel then select the resolution option or screen display depending on the version of windows you are using.
Mar 24, 2012 | Samsung SyncMaster 750S Monitor
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
I changed the screen resolution from 1024 768. while booting the monitor goes to power saver mode and displays "Out of Range 53.7KHZ to 60Hz. My OS is Win XP sp 3,
If the monitor is able to display the video after the computer boots, it may be something that you will have to live with.
But, you may be able to specify a different refresh rate based on the ability of your video card. Right click on the desktop, choose properties, then settings, and advanced button. On the new window, click on Adapter, then click on the Display All Modes button. The default for 1024x768 resolution is 60Hz, but your video card may offer another frequency which may be compatible with the monitor.
If you are unable to see anything after the computer boots, restart in safemode, then make the changes.
Is this an older monitor? 1024x768 is an industry default mode / setting. I am surprised that the monitor doesn't like it.
Jun 22, 2010 | LG Flatron L1515S 15" LCD Monitor
I am using an HW173D monitor with Windowsd XP, and everything displays too wide. How can I resolve this problem?
You need to go to your Display Properties (in Control Panel or right-click desktop and choose Properties), go to Settings tab and set the desktop resolution to 1440x900 which is your monitor's native resolution.
If this resolution is not available, make sure your monitor type (found in Advanced options) is set to "Plug and Play monitor".
Dec 13, 2009 | Hanns.G Corporation HW173D Monitor
I just cant change the resolution of my desktop
If you dont have many options at all on what you can do like change the resolution or change the color settings it could be possible that you dont have the correct driver for your video card.
Go to Driver.com
Use the free program that scans your computer and sees what drivers you need to update.
good luck.
Oct 05, 2009 | Dell E173FP 17" LCD Monitor
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Jun 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
HP W1707 LCD Monitor Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
