Question about Zebra Stripe S400 Label Printer
LIGHTS ON PRINTER LOCKED UP
ALL LIGHTS BUT CALIBRATE ARE ON
TRIED TURNING OFF AND UNPLUGGING.
  • 155 Answers
Try a reset: press the PAUSE and FEED buttons and turn the printer, release the keys when label feed.
Posted on Mar 10, 2009
My printer is offline. I have an HP deskjet 3930. I have tried unplugging, disconnecting, turning both printer & comp. off. The green light just keeps blinking. I've cleared all printing.
The green lights blink during the starting phase of the printer. If it doesn't stops blinking then the starting process never finishes, which means that the processor of the printer or the firmware circuit have failed. The only way to replace those is to replace the entire mainboard, and that would cost more than a new printer altogether.
This printer is dead, time for a new one.
Apr 03, 2011 | Gateway Computers & Internet
Won't print- red light lights up when printing a test page. I've tried resetting the printer (unplugging it and letting it sit for over 1 minute), I've attempted to uninstall the printer and reinstall,...
I have seen this problem a few times. The problem is occuring because the ribbon spool is popping off it's guide sprockets. Often it will pop itself back on. So when you open printer and look at the ribbon it looks fine. Solution. Make sure that the ribbon core is pushed firmly onto it's guide sprockets. You may have to push the ribbon out of the core with as the soft ribbon tends to fill the gaps in the cardboard ribbon core.
Comments: Apr 25, 2009- Easiest way to verify whether ribbon is causing problems is...
1: Remove ribbon from printer,
2: Perform a calibration routine with ribbon removed from printer.
if this works, (press feed button 6 times to verify correct operation)
3: Install ribbon and perform calibration again. If it does not calibrate properly then know that the ribbon is causing problem.
Nov 03, 2009 | Zebra TLP 2844 Label Printer
Blinking lights and e on start copy
Have you tried re-booting your computer?
Apr 01, 2009 | HP DeskJet F380 All-In-One Printer
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Jul 21, 2008 | Printronix T5000r Label Printer
EPSON STYLUS PHOTO RX425
hi if all the lights are flashing and if you have tried turning printer off and unplugging it from power supply and still you are getting the same error lights then chances are thats a hardware issue already.
call epson support so that they can assist you regarding the warranty status of your printer. Thanks for using Fixya!!
Jun 21, 2008 | Epson Stylus RX425 Multifunction...
Uneven ink
try to clean and calibrate the cartridges with printer softwar
Nov 03, 2007 | HP DeskJet F380 All-In-One Printer
Zebra Stripe S400 Label Printer Logo
111 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
