Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Hoop errors I have a CE-350 I have the large hoop installed and the error keeps coming up E6 - need large hoop - HELLO the large hoop is installed. I have tried re-booting computer and machine. I have followed set by step instructions and I still get this error. Do I have a dud. This is a brand new machine I have not yet used. any suggestion ...remembering I have already tried EVERYTHING that the tutorials and futura support have suggested. Please help I do not want to send my machine back if I don't have to
  • sticky11 Jan 22, 2009
    as per my singer sale person the pin that holds the hoop is bent and needs to be serviced........Sounds like it is pretty sensitive......
  • JackiS582 Apr 21, 2009
    When I replace an empty bobbin during embroidering a design, I get the E6 error code although large hoop is attached. This is making me crazy! How does one change the bobbin mid-design without having to deal with this "glitch?"
  • 3 Answers
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
Posted on Jun 10, 2009
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
WHEN I SEND DESIGN TO MACHINE MY HOOP DOES NOT GO TO THE RIGHT PLACE THIS IS A EMBORIDY SEWING MACHINE SINGER FUTURA
Keep trying. I read on the Future web site, that there is an "order" to staring. The software assumes you are using the large hoop. Every thing needs to be in place, before you turn the Future software on. Then the hoop should move to the correct portion. I just get mad and move it by hand. Check out the FAQ on the web site.
Aug 15, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Hoop arm won't slide to start position
You can try re-loading the program, it is possible the static spark has corrupted one of the chips if this is the case and the re-loading does not fix the problem then I am afraid you need the services of a sewing machine tech.
Jan 28, 2008 | Singer CE-100 Futura Computerized Sewing...
180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Dec 21, 2007 | Bernina Artista 180
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
419 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
