Question about iSymphony Televison & Video
I need to find the VESA pattern on the back of the iSymphony LC37iF80 TV
I need to know the VESA pattern and the size of the screw needed to mount this TV properly. Thank you
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
I need to mount my Olevia 237-t12 to the wall, but I can't find the manual to know what VESA mounting standard it is. What size mount do I need?
Just measure the 4 monitng holes spacing on the back in millimeter to get the VESA number.
It should be one of these: http://www.mountcenter.com/VESA-Mount-Standards-s/367.htm
pattern.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 07, 2011 | Olevia Televison & Video
What type of screw is needed to connect the bracket to the back of my 32inch emerson tv?
You would use vesa screws 4mm x 10mm - for non-recessed vesa mounting holes.
4mm x 20mm + approx 1ccubewi_0.pngm spacer - for recessed vesa mounting holes
Mar 28, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Mar 10, 2011 | Televison & Video
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
I have a Samsung LN32A450 and a Peerless SGLs01 mount. I need to put on the universal bracket onto the back of my TV but the back of my TV is not "flat", is more like a small S-curve so the lower part is...
That TV is new enough to have a VESA standard connection on the back, try attaching the mount directly to the 4 screw holes on the back, tv's don't normally need an adapter if the back is fitted with VESA. if not you can find low cost adapter plates on www.etvmount.com for the most part any vesa adapter than matches your size will function fine.
good luck-
Will
www.compressionconnector.com
Feb 19, 2009 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
21 people viewed this question
Top iSymphony Televison & Video Experts
Electro Med Services...
ray gallant
Are you an iSymphony Televison and Video Expert? Answer questions, earn points and help others
