Question about Jenn-Air JCD2389G Side by Side Refrigerator
Fridge is too cold
Set on ''1'', still everything freezes in there
  • annettesieve Jan 19, 2009
    thanks robshow, that is not it, fridge is squeaking clean, no water, I'll try the thermostat. Thanks bunches, that is a remarkable service!!
    Annette
  • Rob Houg
    Rob Houg May 11, 2010
    Clean the back of fridge and make sure there is no water in tray in bottom of unit. SHould be a grate you pop out then a catch tray. This may also be in back of unit. Check these let us know
    Sergeant:
  • 367 Answers
Look like T is correct the thermostat is the issue. If your turning down the temp and its still freezing things the thermostat is faulty
Posted on Jan 19, 2009
  • 700 Answers
It looks like the thermostat has gone out on your unit. take the model number and the make to your local appliance store and the should be able to get oyou the right thermostat for your unit. they are not that hard to replace. Just be sure to kill the power first.
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 22, 2011 | Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Fridge freezer HNMF2805-80. fridge is freezing
isnt that the highest you could put it. how about taking it down to 1 or 2. it should say on the nob.
Jan 28, 2010 | Hoover Refrigerators
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Logo
66 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
