Question about Toshiba 50H72 50" Rear Projection Television
MY TV DOES NOT COME ON AT ALL
I HAVE A TOSHIBA 48 INCH PROJECTION TV AND IV HAD IT FIXED ONCE ALREADY BECAUSE IT NEEDED A NEW PROJECTOR BULB AS MY TV WENT GREEN,THIS TIME ROUND WHEN PRESSING THE ON BUTTON ALL YOU GET IS A DOUBLE CLICK INIDE THE TV AND A CLOCK LIGHT STARTS FLASHING ON THE TV FACE.CAN YOU HELP THANKYOU
  • Anonymous Nov 26, 2007
    doesn't power on.blinking light.
  • Anonymous Dec 01, 2008
    same problem bro, guess it needs more fixin.
  • 398 Answers
I have seen this symptom when the vertical output IC has cracked or burned out, and the set is shutting down to protect the CRT's. When you press the power button the computer clicks the main relay and the set powers up, but a fault is immediately detected and the computer shuts the relay off, giving that double click sound. The circuit should be repaired by someone with experience.
Posted on Jun 28, 2007
SOURCE:
Orange light came on replaced the bulb after a day it blew out then replaced bulb again blew out now the light is red please help
It sounds like it is not getting enough cooling. Clean the cooling paths. I am just taking a guess as I am not familiar with this unit.
Jun 16, 2014 | Toshiba 72HM195 72-Inch Diagonal...
Toshiba 47 inch lcd just developed a yellow smudge to one side of screen
does it take new bulbs? whenever i have this problem with my projectors it needs a new bulb, hope that helps
Aug 25, 2012 | Toshiba REGZA 46RV530U LCD TV
What's your problem?free owners manul Toshiba 57H83 57-Inch HDTV-Ready TheaterWide Projection TV
Please send me an email to LBrown18062@hotmail.com and I will send you the manual. Please put " toshiba 72hm195 manual" as the subject
Dec 23, 2011 | Toshiba 72HM195 72-Inch Diagonal...
Free owners manul Toshiba 57H83 57-Inch HDTV-Ready TheaterWide Projection TV
Please send me an email to LBrown18062@hotmail.com Put "toshiba 57h83 manual" as the subject and I will send you the manual right away. Lawrence Brown
The screen is almost totally black.
You may need a new projector bulb for your tv. Search for "JVC Projection TV Replacement Bulb" + your tv model number on amazon.com and you should be able to find one.
Once you have the bulb, refer to your TV manual to install the bulb.
Apr 22, 2011 | JVC Televison & Video
For a while there was a whining sound - as if maybe a cooling fan motor wasn't working properly? finally the bulb must have blown, because now there's audio, but no picture. what do i need to do? ...
Hello sir, hi, this requires that projector be checked, to fine the whining sound this requires disassembly, or have the unit checked for loose fan blades by a technician, and find that whining sound. If not replacing the bulb is useless, the bulb will always blow up.
Nov 13, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba 50 inch rear projection tv has audio but no video.
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 13, 2010 | Toshiba 50A50 50" Rear Projection...
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Toshiba 50H72 50" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
