Question about HP COMPAQ DC5850 SFF ATH/5000 2GB80GB COMBO WVXP PC Desktop
Hp compaq dc5850 pc won't turn on after plugging in old hard drive for transfer
I unplugged my hard drive (internal) and connected and old one to transfer some music. Now I cannot remember where the p2 connector goes! I took it to a computer shop and he didnt plug in the p2 plug so maybe I don't need it? I had disconnected and reconnected my hard drive before but now it won't start. Would that be because I don't have the p2 cord in? The cord colours are yellow, orange, and 2 black with a white end. It seems odd that I have been able to transfer over hard drives before (quite a few times) without issue, and now it's not working.
the logos1
  • 8 Answers
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
Posted on Apr 01, 2009
  • 323 Answers
SOURCE: Monitor reads: PC entering power saving mode then shuts off;PC on
First do not take the hard drive out and put it in another computer. It is configured to run in the computer it's in.
Next, you probably did have a power surge either from your power supply or the power in your home. It sounds now like your power supply is damaged.
The processor does not have any gears; the sound you hear is most likely the fan in the power supply running too high.
Taking the battery out does nothing unless you move the jumper on the rtc to clear the CMOS. You should do that. You will have to get the computer running before you can transfer via USB to a flashdrive.
Unless you know what you are doing, you can ruin your computer just by touching components or the motherboard. You need to ground yourself first and make sure the computer is unplugged from the wall.
Here is what I recommend:
1. Get a grounding strap and hook it to your wrist and something to ground it. The package will tell you how.
2. Open the computer case and move the jumper to the proper location to drain the CMOS. (There will be 3 pins, and it will be on two of them. To ground it move the jumper to the uncovered pin and the one next to it. Leave it there a minute then remove it and out it back on the other two.
3. Be certain the two sticks of ram are properly inserted all the way in the slots; do not use brute strength.Leave the side cover off, and plug the Computer back in again. You should see a light come on after a few seconds. You should also see the power supply fan on.
4. Turn on your monitor and then boot your computer. If it comes to a screen that says it stopped abnormally, choose the last known good configuration.
5. you don't get that far you have worse problems, namely the motherboard or the powersupply. If it boots you should also hear the hard drive whirring.
If you can't get it going let us know. But one thing I'd like to convey to you. There is nothing in your conputer any reputable technician in a good shop will want. Neither will he put malware on your system.
Sirwriter
Posted on May 13, 2009
  • 169 Answers
SOURCE: Power Issue on my HP m7470n
try this link.....it has the steps you need to follow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01732674&cc=us&lc=en&dlc=en
Posted on Jun 24, 2009
  • 122 Answers
SOURCE: My HP Pavilion computer unit will not turn on.
If you have no activity at all, no lights, no noise at all etc. it is probably the power supply. It can be replaced with some mechanical skill and attention to where the wires plug in, but the major problem is the age. Older computers have a different power supply then currently available. If you have data you need to retrieve the physical hard drive can be removed and placed in a relatively inexpensive USB housing and accessed from a new computer. If you want to try and get it repaired find an older, small repair shop and with luck they may have or be able to locate the correct replacement. Since it is 10 or more years I would not put much money into repairing it so check in advance about minimum rates etc. so you don’t end with a money pit. Good Luck
Posted on Jul 20, 2009
SOURCE: POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Posted on Aug 28, 2009
Problem with COMPAQ DC5850 SFF ATH/5000 2GB80GB COMBO WVXP PC Desktop hp compaq dc5850 pc won't turn on after plugging in old hard drive for transfer Posted by Author imageGuest on 1/4/2013
The h3ll you say.
(Kidding around)
Let me see if I understand this straight;
You unplugged THE harddrive to your computer..............
Then you plugged an old harddrive in, and expected to be able to use it.
Expected to because you've done it in the past.
Really
Curious;
1) Was it an old harddrive you had in the computer, removed it; and had a larger one installed?
2) Is it one that you have had in another computer?
Here's what I know, and why I'm asking;
When Windows is installed on a computer it assigns hash values, to certain major hardware components.
For example;
A) Processor
B) Motherboard: To include the motherboard chipset, and BIOS program. (To include version and date)
C) Harddrive
D) Graphics chipset
Change any two of these hardware components, and Windows will think it is being stolen. Put on another computer.
Microsoft User's License states, "One GENUINE copy of Windows per ONE computer"
(Microsoft makes one Master disk, and from it all GENUINE copies are made, and sold to the consumer)
Now if you stated you installed the old harddrive as a Slave drive; then I could understand.
P2 connector?
That is a Power Supply power cable.
According to specifications the Harddrive is a SATA unit.
http://h10010.www1.hp.com/wwpc/ca/en/sm/WF06b/12454-12454-64287-3328896-3328896-3658105-3687950.html?dnr=1
Internal Drives - Hard disk controller -SATA 3.0Gb/s NCQ SMART IV
The power cable to it is a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Probably what your P2, and P3 power cables are.
http://www.ebay.com/itm/HP-DC5850-SFF-Motherboard-SPS-461537-001-/310417711958?pt=Motherboards&hash=item4846566356
P1 will be a 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
P4 cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
P5 cable, MAYBE, (Might be P3 too)
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
And P6 power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
This type of power cable is also used on a Card Reader.
To conclude;
A) SATA harddrive has to have a SATA power cable, and SATA data cable.
The SATA power cable's connector is wider, than the SATA data cable's connector.
15-pins for the SATA power cable connector; 7-pins for the SATA data cable's connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The above is a general example of a SATA data cable, and it's respective connector on the motherboard.
Your SATA data cable connectors on the motherboard, are of a different style than the above.
You have Four SATA connectors on the motherboard;
1) Light Blue
2) Orange
3) Dark Blue
4) White
Regards,
joecoolvette
Jan 04, 2013 | HP COMPAQ DC5850 SFF ATH/5000 2GB80GB...
Computer won't come on. light is blinking in back of hard drive.
Try unplugging from wall socket then press on button (this clears out extra electricity in PC). Plug back in then try to turn on again. If PC is older, try blowing out the dust inside tower especially around the CPU fan.
Aug 04, 2012 | Compaq Computers & Internet
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Nikon P80 Transfer problem. The Nikon Transfer program either stalls and will not process. I have to turn off and unplug the camera and start the process again. After several attempts and a long period of...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jul 06, 2009 | Nikon COOLPIX L3 Digital Camera
June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
PAGE 39
1. Unplug the AC adapter, if present, and then remove the battery.
2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
M2.5×6.0mm screws. (The number of plugs and screws varies by model).
3. Carefully pull the hard disk drive out of the notebook.
4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
and then lift the drive out of the tray.
5. Remove the connector bar from the hard disk drive.
The manual does have little picture to help you. The link above is to download the service manual.
Jun 23, 2009 | HP Compaq Business Notebook NX9010
HP COMPAQ DC5850 SFF ATH/5000 2GB80GB COMBO WVXP  PC Desktop Logo
37 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
