Question about Whirlpool Washing Machines
Cabrio wtw5550xwz makes funny noises agitating and spinning out
Sounds like gears meshing together when it agitates then it makes noises like the sides of the drum hitting the sides
Oceti
  • 51 Answers
SOURCE: Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Posted on Dec 07, 2007
  • 1028 Answers
SOURCE: during spin cycle started making
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
Posted on May 20, 2008
  • 3 Answers
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Posted on Jul 05, 2008
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
SOURCE: Washing machine making loud noise when agitating/spinning
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Posted on Jun 30, 2009
Cabrio washer 5d error code
chances are the 5d error code you see is actually sd. it is supposed to signal excessive suds in the water but it seems to show at other times as well. but regardless of the code and depending on you mechanical abilities, remove the center cap on top of the agitator, remove the bolt and remove the agitator. some force may be needed to get the agitator off the shaft, keep equal pressure 180 degrees apart and work around the base lifting the agitator, gently rock the agitator as you lift. when it comes off take the screws from the gear hub assy out, probably six screws. when the cap is lifted off you should find a small gear, pull it off the shaft, clean and look at the teeth inside. if worn, get replacement part. put back together and run a rinse and spin cycle or similar to see if it spins . hopefully it will solve your problem.
May 31, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin and smells funny
Does the washer agitate while in wash cycle? Does it move at all? It may be that the motor that drives the spin and wash cycle is not working. If it smells funny, it usually means that you have bearings gone bad or a belt, if it is belt drive, broken. You can replace these parts. All the parts involved with spinning can be replaced. The parts are available from the maker. It may be a spin clutch, agitator gear, pulley, or a transfer case..
Please leave good ratings, email me if you have more questions
Aug 07, 2009 | Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Washer makes grinding noise
many of the Maytags have had a problem with the pump bearing. This is what it sounds like. Tilt the washer back. Look underneath and take the belt off. The pulley on the pump is metal. try turning with your hand both ways. If it grinds that is problem. Let me know if need more info.
May 22, 2009 | Maytag Washing Machines
AGITATOR DOES NOT MOVE, MAKES FUNNY NOISE
Will it spin if no then you need a motor coupleing if yes then agitator dogs in your agitator are wore out
Mar 29, 2009 | Whirlpool Washing Machines
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Dec 07, 2007 | Magic Chef CAV2005A Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
