Question about Lexmark Optra T610 Laser Printer
Lexmark Optra 310 paper jam
Hello and thanks in advance!
The problem i'm facing is that the printer for a single paper print grabs a lot of paper instead of one at a time.How can i solve this?
  • 320 Answers
Try fanning the paper prior to putting it in the drawer. use contact cleaner on a rag and clean the pick wheels. turn the printer onto its back to look at these. these wheels get a yellowish build up on them from the glue in the paper and the glue makes them smooth.also there is a balance spring that hooks to the autocompensator arm that the wheels are mounted to try moving this back one notch this will lighten the downward pressure applied to the paper this should fix your problem
Posted on Sep 04, 2010
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Lexmark optra s1855 paper keeps jamming
check this site http://www.ehow.com/how_5326976_fix-carriage-jam-printer.html
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Lexmark Optra S 2455 Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
Optra S 1625 - not printing an inch on the right side of paper
CHECK THE PAPER WIDTH SETTINGS IN YOUR PRINTER SETTINGS ON YOUR PC OR YOUR PAGE SETTINGS TO SEE IF THERE IS A NON STANDARD PAGE SET UP
Oct 18, 2007 | Lexmark Optra S 1625 Laser Printer
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
