Question about Fuji FinePix 2800 Zoom Digital Camera
Battery corrosion I had not used my camera in about 2 months and never thought of taking out the batteries. When I tried to use it,,,I thought it just needed new batteries because it was turning on for a few seconds then shutting itself off. I opened the battery door and found that the batteries were super corroded. I was advised to use elecrical contact cleaner to clean up the corrosion and after doing so,,,it still will only turn on for maybe a couple seconds and then shuts off. What more can I do to salvage this camera?
  • Anonymous Mar 26, 2014
    The alkaline batteries leaked while camera was stored. How does a person clean off this crud?
    Genius:
  • 2,985 Answers
Carry on cleaning the contacts -perhaps a little abrasive cleaning with a pencil eraser- may do it.
Posted on Jun 30, 2007
Camera switches off as soon as it's turned on. Batteries are fully charged. Camera has not been used for seven months. What could be wrong?
If you have not used your camera for few months the problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Thank you !!
Jun 27, 2010 | Kodak EasyShare Z740 Digital Camera
I made the mistake of buying another Kodak camera and this one is only 9 month old and only used 3 time in that time. When you turn it on it turns right off. I put in new battery and the same thing...
Batteries tend to deteriorate and leak over time, especially if left in a camera when it's not used for several months. Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 15, 2009 | Kodak MX1063 Digital Camera
Our Canon PC1038 will not turn on; battery has been charged.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Cameras
Our Z712 IS turns on sometimes and then it
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 27, 2009 | Kodak EasyShare M853 Digital Camera
Lens and shutter jammed
Nov 06, 2009 | Panasonic DMC-FX07 Digital Camera
I have had my camera for just over 2 years.over the last 6 months i have had problems with the battery side. i have used the correct batteries, within 10 minutes the camera drains batteries with occasional...
Oct 25, 2009 | Kodak EasyShare C633 Digital Camera
A640 freeezes while taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon PowerShot A640 Digital Camera
Batery problem
This usually occurs when the camera is exposed to water, sweat, high humidity or if you had leaky alkaline batteries. You have 2 choices to try. 1 take the camera apart and use an old toothbrush with WD40 and scrub the circiut board, you can inspect the battery compartment to see if you have corrosion from leaky batteries and do the above to fix. 2 use the camera as is and remove the batteries after each use.
Jan 07, 2009 | Sony Cyber-Shot DSC-P41 Digital Camera
Fujifilm S3100 won't power on
I'm not familiar w/ the S3100 but do you see any corrosion in the battery terminals? These camers don't usually just quit working. If the terminals are clean, what battery are you using? How many mA or milliAmpere rating? These are usually indicated on the rechargable battery's sides. There are some new battery in the market. The eveready silver colored battery. I forgot the name. It is one notch above the regular alkaline battery. Let me know if this helps.
Jul 20, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
62 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
