Question about Fellowes P50CM Shredder
The plastic gear which drives is worn out can i get a new one
The moter runs not the shredder rotates
3 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
Repair
There are no adjustments for this machine. Chances are that the plastic gear that is driven by the worm gear has a spot that is worn down and when worm gear hits this spot, it does not drive . Replacing gear is the only remedy. Good luck.
Jul 13, 2013 | Fellowes MS-460Ci Shredder
Hi, One of the plastic gears inside the gear
Honestly Dennis - these bad boys are quite vicious and go up like jack-in-the box when you attempt to take them appart - I would recommend you bin it and buy a new one.
Mar 18, 2011 | Tech Solution TS-6000 Shredder
Nylon drive gear worn on one side
I have been told by the manufactutere that they do not make any replacement parts for their shredders. If it is less than a year old they will replace it.
Jun 20, 2010 | Aurora Electronics AS1018CD Shredder
Plastic gear is wore out. the motor shaft wore it
My friend, if the gear is worn out, your machine is worn out. By the time you get and in stall this part, you can purchase a new machine.
There is a possibility that Royal will sell you the part ... you could check with them. I have never had luck repairing any but LARGE COMMERCIAL shredders. Home and small office shredders are not worth the effort to repair.
Feb 13, 2010 | Office Equipment & Supplies
Shredder motor runs but gears are not engaging and will not take up paper to be shredded. Model is Royal VF1012mx
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Jun 30, 2009 | Royal VF1012mx Shredder
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Fellowes P50CM Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
