Question about Toshiba Satellite P105-S6024 Notebook
My fujitsu laptop knows it is plugged in but wont charge
As above
My fujitsu wont work without its charger and when the charger is plugged in it wont actually charge the battery itself.
Probably your battery is dead because if there would have been any problem with your charger port, you cant be able to use it on plugged mode. Buy a new battery ASAP.
Dec 29, 2014 | Fujitsu LifeBook AH532 Notebook
Not charging
The battery is not working as it should. Either, replace the whole lot under warranty or leave the battery on charge until it will accept a charge.
Dec 27, 2013 | Fujitsu LifeBook Computers & Internet
No Battery Warning - Turning off at 20%
May be time to replace the battery.. or charging problem i advise you to take it to the service center.
Aug 13, 2013 | Fujitsu LifeBook Computers & Internet
Fujitsu n3410 wont charge
Unfortuneately that leaves the charging circuits on the motherboard that must be faulty, "this is so rare I have seen only one in all my years of service". But I think it is a good idea to have the charge circuits tested to be sure.
Apr 23, 2012 | Fujitsu LifeBook N3410 Notebook
FUJITSU SIEMENS S6010 WONT TURN ON, HELP!!!!
Hi, I have alot of Motherboards for that Laptop. Maybe a New Motherboard Needed. CPU May have Burned out?
Email: microxtremecomputers@live.co.uk
Jan 28, 2010 | Fujitsu Siemens Computers & Internet
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Battery won't charge
Completely drain the battery so the computer wont even switch on and charge it over night. If its still not working after that then you need to get a new battery.
Jan 19, 2009 | Fujitsu AMILO Pro V1000 Notebook
Updating the RAM memory
http://www.memoryx.net/fulisme4.html
click the link above for the correct ram to purchase
Most likely your bought an incompatible ram for your unit. Return it and buy from the link above
Apr 07, 2008 | Fujitsu LifeBook S-4572 Notebook
Toshiba Satellite P105-S6024 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
