Question about Microsoft Xbox 360 Console
Can't get the scoring to work on lips - stays at 0
We tried it for first time yesterday - not sure whether maybe I havent set it up properly
  • liz_russell Jan 25, 2009
    Thanks - we fixed the problem though - the mics weren't synched up properly! All go now and we've had heaps of fun since.
  • 3 Answers
Have you tried phoning up microsoft or phoning up inis or any other companies to do with lips because it may just be something you need to quickly do to make it work so try phoning them up
Posted on Jan 20, 2009
It is as if it dosn't help to chance the number at the tension wheel.
Remove the upper thread completely from the machine.
Could try cleaning the tension disk: Raise the presser foot, set the tension to zero, dampen a length of pearl cotton with rubbing alcohol, then gently pull the pearl cotton Down through the tension disk a couple of times.
Install a brand new needle & confirm that the needle & thread are compatible.
All About Needles
Make sure to RAISE the presser foot while threading the upper thread. This allows the thread to seat properly in the tension disk. Of course, it could be that the tension disk is broken or not operating properly.
Feb 21, 2016 | Sewing Machines
My zte score will not turn on it just shows the logo
Try to check with a different battery and also charge with a different charger if this doesnt work then contact the Metro PCS for help.
Dec 21, 2012 | ZTE Score
How do you score in a game of darts?
This really depends on what style game you are playing. I will explain how to score with a game of 501. Each player starts the game with a score of 501. Players' scores are then deducted from the original number - with the goal being the first to reach 0. To get a 0 you will have to score a double on the last dart.
For any dart that lands in a non-ringed area you score the number shown on the outside of that segment. If a dart lands in the outer ring it counts as double the normal score and any dart landing in the inner ring is scored three times its normal value. The outer bull scores you 25 points and the inner bull scores you 50.
Jul 26, 2012 | Sport & Outdoor - Others
Hotpoint hts17gbserww My refrigerator section is at 32 degrees, but the freezer is only 18. The single contriol setting is at 4. How do I get the freezer closer to 0 degrees and the fresh food section a...
Sorry to read about your problem, I hope this helps you out.
if you have the freezer set to the coldest setting, you may want to check your door gasket.
Try and put your mouth/lips close to the seals, your nose/lips can sense cold very well. if you feel cold coming out, replace the door gasket.
if the door gasket seems ok, you maybe low on freon, or a defective temp sensor. or you may even have a defrost problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Avanti FF1101W Top Freezer Refrigerator
I am in Zimbabwe. i recently bought a Nokia 7210 Supernova and the problem is i am failing to configure it to internet. i don't how to as the phone is saying data connection failed every time i try to log...
In order to solve the internet problem in phone kindly check: *whether your gprs connection is active. *configuration settings are properly filled. *home page is properly set. *verify whether your staying, where you get range. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Aug 23, 2010 | Nokia 7210
I got a new key board it was working yesterday when i kept switching my pc on and off but today it wont work what cud i try
Hi
Please check whether your keyboard is properly plugged in to your computer. If it is plugged in properly then try and change the slot of the keyboard(if its a USB port keyboard). If this doesn't help then try to check the BIOS settings for keyboard settings.
To enter BIOS settings press DEL key continuosly or F8(Function key 8) continuosly until the BIOS menu appears. Under the menu select the option of Hardware->Keyboard-> check whether it is enabled or disabled. If it is disabled then enable it.
Try using this keyboard with another Computer, if it doesn't work with other Computer as well then you can get it replaced for a new one.
Daniel Scott
Jun 12, 2010 | Computers & Internet
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Pronblem with mics
Make sure that the mic's turned off and then make sure you lower the mic's volume to the max then plug it into the controller
Sep 25, 2009 | Microsoft Xbox 360 Console
Installing
1. if your internet service provider did not provide these to you, they would stay blank. (most cable broadband internet would have these blank, for instance)
2. because you havent entered any dns entries. more importantly, most of the time what is more important is that you router is set to obtain dns from your ISP (service provider) if that is set correctly, its ok that they are all 0's
3. whether or not your connection should be set to the automatic type can only be answered by your service provider, most cable and some DSL broadband would be set to automatic, some DSL will be set to PPPOE, which will require the username and password given to you from your ISP. If they did not give you one, most likely this would be set to automatic.
4. DHCP server functions is what allows your individual computers in your home to share the internet if you have more than one machine. even if you do have just one machine, it should still be set to automatic.
5. The router name is for your reference, so you should name it something that is meaningful to you.
Mar 21, 2009 | ASUS (wl500g) Wireless Router
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
