Question about Garden
My ryobi rpt 324 weed eater cord hangs out and doesint want to go back in can sombody tell me how to ge it back in irgent!!!!!!!
  • 3 Answers
SOURCE: Ryobi string trimmer -weed eater pull cord hangs out wont start
What model number is your Ryobi?
Posted on Jul 25, 2008
  • 570 Answers
SOURCE: mt ryobi pull cord shreaded
Go to following site http://hcpi.arinet.com/scripts/EmpartSAPI.dll?MF
Then type in your model no.
Do not know your model no. but normally you have to remove the shaft. First remove the throttle cable from carb. and disconnect the switch wires from shaft. Then pull shaft out of motor housing. There should then be a couple of screws in the shaft housing, remove them. You will then have to remove the clutch and drum, notice if there is an arrow on the clutch to show which way to remove. Use a brass or copper bar to strike the clutch to loosen in direction shown. If you have compressed air and an impact that would be a better choice. Now remove the four screws holding the starter housing and you should be at the starter rope.
Posted on May 05, 2009
  • 323 Answers
SOURCE: do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
Posted on May 23, 2009
  • 168 Answers
SOURCE: i have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Posted on Oct 03, 2009
Testimonial: "i,ll try this thanks a lot "
  • 2239 Answers
SOURCE: My Ryobi weed eater will'not rev up and keeps dyeing
Normal reasons for not reving are, blocked air filter, blocked spark arrestor in the muffler, or blocked exhaust port ( with carbon )
Posted on Feb 17, 2012
Ryobi electric hybrid weed eater quit working.
are there weeds stuck under the trimmer head causing it to work too hard perhaps and even short cords if not heavy enough will cause problems and burn out the motor
Jul 18, 2015 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Feb 16, 2012 | Isuzu Rodeo Cars & Trucks
Sparkplug gap for a 31cc ryobi weed eater
If its a 725r ryobi weed eater it takes a champion RDJ7Y with
a gap of 0.020 in. or (0.5mm) with a feeler gauge.
torque @ 110-120 in.lbs. good luck!
Jun 28, 2011 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
Ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
Dec 08, 2009 | Ryobi Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Do you use mixed gas for a ryobi weed eater??
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
