Question about Xerox Phaser 7750GX Laser Printer
Toners i have a xerox phaser 7750 and need to purchase toners in miami, is it possible for u to locate a cheat store who supply it
    Guru:
  • 110 Answers
You can get some cheap toner from www.iteminconline.com OEM toner. I bought some 3rd party toner once and since it was not OEM it kinda clogged my developers. So i called Item inc told them my problem and they said to replace the developers and the toner.. it was to cheaper to buy it refurb. So I saved alot of money and my printer is working great. Give them a call I"ve bought already 3 refurb cyan toner they always work. "printing alot of blue pages". good luck
Posted on May 21, 2009
    Genius:
  • 2,120 Answers
Staples, Office Depot, Best Buy
Posted on Jan 19, 2009
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Is it possible to empty and reuse the waster cartridge for the Xeros 7750?
Hello, yes it is possible but it is also very messy and a pain. You must dump all the toner out and make sure the sensor is able to pass light through the window on the bottom of the waste cartridge. Xerox suggests that you do not reuse these and they're only $29 brand new from iteminc.com so for most people I'd suggest just buying a new one.
Feb 07, 2011 | Xerox Phaser 7750B Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
May 14, 2009 | Xerox Phaser 7750DN Laser Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750 faulty door sensor
it,s all $$ wherever you go ?
If you can find which wires contact ( Make/Break ) possibly with a multimeter. Remove the sensor, join the wires. tuck it into the inside of the printer.
tape it up to avoid any shorts.
Mike @ compurepair.
Feb 25, 2008 | Computers & Internet
Open Questions:
See all Xerox Phaser 7750GX Laser Printer Questions
Xerox Phaser 7750GX Laser Printer Logo
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
