Question about Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite laptop
After reformatting my hard drive I lost my wireless connection. It does not appear in my control panel and I don't have a shortcut icon in the taskbar tray either. I called Toshiba and they claimed they could fix it for a price. Hmmmm. Any ideas or help would be greatly appreciated.
  • Anonymous Apr 01, 2014
    i can not turn on my wifi manualy or otherwise and it does not even show up on the taskbar or system tray
    President:
  • 2,961 Answers
Go to my computer icon on desktop or on start menu, right click>properties>hardware tab>device manager and look down list for any yellow exclamation marks, if so right click on it and select update driver, making sure you have your installation cd in the drive as the driver may be on there, or look for network adapters and click the + sign and see if your wireless adapter is listed but has a red cross on it, if so right click and select enable. If you dont see anything related to the network card you may have to check in the bios (press F2 or Del on startup) and go into the bios and select the advanced menu and look to see if your wireless adapter is listed in there normally in the hardware section and see if it is enabled, if not enable it save settings and exit for a restart. if you do not have a driver for your wireless adapter click the link below http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=UK
Posted on Jun 27, 2007
"how to clean & install toshiba satellite l35-s1054 win 7 "
Look in BIOS during reboot, make sure the hard drive is detected. Run hard drive test and memory test. Use BIOS feature to setup boot options and boot order, set all to default. Reboot.
Feb 10, 2013 | Toshiba Satellite L35-S1054 Laptop...
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Mar 21, 2012 | Toshiba Satellite L455D-S5976 Notebook
Loss my wireless connection
If you reformatted your hard drive, you'll need to reload the wireless card drivers for the computer. They are not part of Windows.
Feb 23, 2012 | Toshiba Satellite L505D-GS6000,...
Don,t know how to turn on my wireless on laptop?
go to Start > Control Panel > Network Connections > Wireless Connection. Then right click it and click enabled..
Jul 16, 2011 | Toshiba Satellite A60 Notebook
How do I recover my administrator password?
Hi, man. Don’t worry, there are many people forget their admin password or lost it, and there is a popular solution for those who have been locked out by computer. For this solution, what you need is a second computer that can connect to Internet and then freely download Windows Password Recovery 6.0 at http://www.recoverlostpassword.com/products/windowspasswordrecoery.html With it, you can create a reset CD which can be used to reset Windows admin password without erasing anything.
Jan 05, 2010 | Toshiba Satellite R10 Tablet PC
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Is there a wireless card in the toshiba satellite 1415-s173?
Go to Control Panel > System > Device Manager
Under Network Adapters you would be able to locate wireless card if its there in your system.
Sep 19, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
My disk drive is loading on my Toshiba laptop My DVD Drive isn't
turn off your pc,open your pc try to remove the dvd drive and put it back again.turn it on you must see your dvd drive from the opening .if its still not appearing go to control panel,click the add hardware.make sure that you plug it correctly.
Feb 20, 2009 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
326 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
