Question about HP Compaq d530 PC Desktop
Error 162 system option not set
Starts up but i get error messages 162-System options not set It used to have a power-up password but i removed it by removing the jumper under the battery now after the memory check and error messsages it says the configuration options were automatically updated. The default Values were loaded it says to press F1 to Save the changes. i try to press F1 and nothing happens im using a USB Keyboard which works because during memory scan i can press F9 or F10 to go into boot or set up. although it doesnt actually go into boot or setup it ignores me :( I've Tried a PS/2 keyboard. no luck. what do i do now? the motherboard: HP d530 SFF(DC578AV)
3 Suggested Answers
Wonder Wizar
  • 62 Answers
SOURCE: dear sir i have hp
  1. Click Start, right-click My Computer, and then click Properties.
  2. Click Device Manager.
  3. In Device Manager, expand Processors.
  4. Double-click the processor, and then click the Details tab.
  5. Click to select the Hardware Ids in the drop-down list.
  6. Examine the information in the details pane to determine whether the computer uses an older Intel Pentium.
Posted on Apr 12, 2010
SOURCE: My hp pavillion Media center
Welcome to Fixya
You are having that issue because the system is not able to detect the operating system of your computer. This could be caused by two reasons, The hard drive of your computer may already be defective and is no longer detected by the computer or the operating system of your computer is corrupt.
If this issue is caused by a corrupt operating system then you can try to press F11 for system recovery. This would cause the system to restore to its factory condition. Please note that this step would cause you to lose data on you computer.
You can also try to press F9 to run diagnostics on the hard drive of the machine. If it displays an error the hard drive of your computer is defective and you would have to contact HP to check If you still have warranty and get a replacement Hard drive
Hope this helps
Posted on Jun 30, 2011
System options not set hp compaq dc 7600
Make sure your clear cmos jumper is not in the clear position! It is usually close to the battery and there is labelling on the mboard near it. If you're sure you didn't move it, then don't worry about that.Did you try setting the bios to defaults?
One possibility - it could be it does this if you don't re-set at least the date (and possibly the time) in the bios from the default it sets itself to when you remove the battery or use clear cmos - set it to today's date and time, or to anything other than the default, save settings.
If after you save the above settings, turn off the computer for a few minutes, and check the bios again, the date and time re-sets to defaults, then the cmos doesn't see the battery. If the date and time are consistant with what you set them to, it is seeing the battery.
By the way, I don't think this is the problem because you have the 162 error code, but make sure the battery polarity is right - is in the holder the right way - and the contacts for it are making good contact - if it is the wrong way or the contacts are poor, the cmos will think there is no battery. Usually you can tell by the way the contacts are arranged which way it goes - if it is the wrong way both contacts touch the same part of the coin cell (if that is what you have) - usually + is upwards.
If setting the bios to defaults, setting the date (to anything other than the default) does not get rid of the error message, try making sure everything on the board is properly seated. Unplug the computer when you do that!
.........it says memory error, below that it says 162 System Options not set, then it says 164 error.
(later)
I just took everything that would unplug and reset them in and it corrected the problem. Thanks
That error code is common on many computers, and in many bioses.
e.g.
161 POST Error - System options not set - (Run SETUP) - battery
162 POST Error - System options not set - (Run SETUP)
161 System options not set; dead battery
162 System options not set; CMOS checksum/configuration error
If it is 161 the battery is dead, it is installed with the polarity backwards, or the battery contacts are not making good contact.
If it is 162, there is nothing wrong with the battery - you need to go into the bios Setup.
I have found nothing other than the above post about what to do about that.
If you still have issues, go to and talk to one of our techs
Clean Optimize Speed Up and Secure PC Freeware Download EZ System Repairs
Oct 15, 2015 | HP Compaq dc7600 Small Form Factor PC...
Hp nx6110 laptop is power lock what is unlockng process
Disconnected the RTC battery will unlock your system. See the steps below.
The more important it is to protect on's data by a DriveLock (which makes the HDD usuable when the password is not available).
Procedure to remove password
(following CPQ MSGs)
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. Half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Warning: All settings are set back to factory standard.
You'll have to enter a correct date/time and change the settings to your needs.
Note: Pls strictly keep to the sequence.
Re-starting with the main battery and or RTC-battery inserted will spoil the job.
Apr 04, 2013 | HP Compaq nx6110 PC Laptop
I need administrator password for compaq nx6110
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
I have a password problem on my laptop,but not window password it board password please help my out.
If you are talking about the password that is just ask when the comp starts....You can try this...
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a â 162 System Options
not setâ message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
May 06, 2011 | HP Pavilion dv6000z 15.4" Notebook Laptop...
I dont remember power on password for hp nc4400
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
We are away from our principal home. My wife called to access phone messages and inadvertently must have turned the answering system off. Is there a way to remotely turn the answering system ON? Thank...
Turning on the answering system
Call your unit and wait for 15 rings.
•The unit will answer and the greeting message will be played.
•The answering system will turn on. Hang up or enter the remote code for other
options.
•When turning on the answering system using a rotary or pulse service telephone,
you cannot enter the remote code for other options.
Oct 01, 2010 | Panasonic KX-TG2257 Cordless Phone
101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
Jun 08, 2009 | Compaq Armada M700 Notebook
My laptop compaq armada1700 ask me power-on password what can i do?
Follow the instructions of the service manual for the Armada 1700 (you need to have some skills):
2.2 Clearing Passwords
The power-on password prevents use of the computer until the password is entered. The setup password prevents unauthorized changes to Computer Setup. To clear the passwords, you must remove all power from the system board. If you do not know the passwords, use the following procedure to clear the password:
1. Remove all battery packs from the battery bay and MultiBay, if applicable.
4. Wait five minutes.
6. Restart the computer. During Power-On Self Test (POST, a "162 System Options not set" message appears.
10.Proceed with the troubleshooting procedures.
Point 10 means you need to do the setup via disquette to set the date and time again, to avoid the "162 system option not set" message of the POST.
Lucas from Argentina
Mar 22, 2009 | Compaq Armada 1700 Notebook
HP Compaq d530 PC Desktop Logo
44 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
