Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Carbon monoxide alarm sounded this morning I think the problem comes from the heater unit, also the unit on the other bedroom does not heat at all
    Scholar:
  • 144 Answers
Call for service NOW! DO NOT delay. This can be a dangerous life threatening condition. I'm not kidding.
Posted on Jan 20, 2009
What makes a ventless gas heater put out carbon monoxide fumes
Any gas appliance that burns gas puts out Carbon Monoxide. The trick is to make it not too much, however, how much is too much. Read this;
http://www.ventfree.org/content/view/42/18/
and there are warnings here too;
https://www.angieslist.com/articles/are-ventless-fireplaces-safe.htm
and a list of the potentially dangerous gases they omit;
https://www.abe.iastate.edu/extension-and-outreach/carbon-monoxide-poisoning-unvented-gas-space-heating-appliances-aen-204/
I would not use one unless I had good ventilatioon and a better Carbon Monoxide alarm.
What makes ventless gas heater put out carbon monoxide fumes Google Search
Jan 19, 2017 | Heating & Cooling
Smell emitting from gas heater
Carbon monoxide is completely odourless and every sort of combustion of a carbon or hydrocarbon fuel produces carbon monoxide. That is why heaters should not be used without adequate and efficient ventilation and heaters should be kept in good order because efficient combustion produces less and inefficient combustion produces more.
Inefficient combustion and the need for service can often be recognised by the characteristic blue flame being tinged with yellow.
Heaters burning inefficiently often produce a smell for the sensitive or stinging eyes but that is not caused by carbon monoxide.
The gas itself is also odourless and the characteristic smell is added to warn people of leaks. I think the added gas smell tends to settle or separate from the liquid gas to some extent so there will be times when it is so concentrated it isn't entirely neutralised by the burning process, at least that is my theory.
Jun 18, 2017 | Heating & Cooling
When i turn the heater on it makes the alarm go off. what could be the problem
If its putting out carbon monoxide the heater is bad. Turn it off and call a heating company.
Nov 27, 2013 | Heating & Cooling
I have just purchased three First Alert carbon monoxide alarms. My home has a basement and bedrooms on the first and second floors. My questions stem from the installation. Should the installation...
When I worked Electrical in a Hardware store we were told by Nighthawk and f\First Alert and we told our customers that you want the detectors 4-6 feet off the floor never near a water heater or furnace since this can cause false alarms. The CO will rise, so one on each floor should be enough near a central stair if possible. Other wise make sure at least one is in the bedroom.
Mar 01, 2011 | First Alert CO400 Battery Powered Carbon...
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My First Alert Carbon Monoxide Alarm has failed
If the carbon monoxide detector chirps, the battery may be dead. New batteries can be defective. Check if the light is yellow when the alarm is chirping, it means the battery is low, replace with a new battery.
Warranty service information:
UNITED STATES
BRK Brands, Inc.
3901 Liberty Street Road
Aurora, Illinois 60504
For consumer inquiries call: 800-323-9005
CANADA
Jarden Branded Consumables Canada
88B East ****** Creek, Unit 6
Richmond Hill, Ontario, Canada
L4B 4W2
Tel: 905-482-3720
Fax 905-731-8267
For consumer inquires call: 800-323-9005
If you are looking for new Carbon Monoxide Detectors, visit my website.
Oct 01, 2009 | First Alert Safety & Security Carbon...
Same alarm problem setting offf
As a camper myself, I know that one of the last thing we check is our Carbon Monoxide detectors in our unit. I had an old Class C motorhome with a CO detector that failed to alert me, and my kids got to the point of being nauseous. We were lucky to discover the problem.
A Carbon Monoxide Detector needs to be changed after 5 years because the sensor is designed only to last this long. If your unit needs to be changed, you can shop online on my website http://carbonmonoxidedetectoralarms.com/
Good luck and happy trails.
Jul 02, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Carbon monoxide is on
When a Carbon Monoxide Detector alarm goes off, you should follow the procedures that came with the manufacturer manual. Even when the alarm sounds, you cannot smell, taste, or see this dangerous silent killer known as Carbon Monoxide.
Have your house checked by your local fire department for possible levels of CO gas readings. If this all checks out, you can go online to Kidde Nighthawk website and find the manual for your Carbon Monoxide detector model.
Hopefully, you found your solution since you posted this question back in Dec, 2008. Go to my website to read industry information and to view most Brands and Models of Carbon Monoxide Detectors.
Dec 16, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
Feb 27, 2008 | Kidde Nighthawk Combo Gas/co Detector
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
64 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
