Question about Music
How to tune guitar with fender fte - 3tn preamp with tuner onboard
  • 5603 Answers
SOURCE: I just got this guitar. I pull the tuner control,
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Posted on Feb 06, 2010
SOURCE: Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Posted on Mar 12, 2010
  • 1137 Answers
SOURCE: I have a Fender CD220SCE acoustic guitar with a
Try this page:http://www.fender.com/products/search.php?partno=0962211021 Hope this helps. If not contact Fender at that site.
Posted on Jun 03, 2010
  • 5603 Answers
SOURCE: Hello, I have found that Ibanez
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Posted on Feb 16, 2011
  • 5603 Answers
SOURCE: Hi i recently bought a
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
Posted on May 03, 2011
I do not no how to tune my electric guitar
you should get a tuner -there are free ones for phones and on the internet. the strings are from thinnist on the bottom E -B -G -D -A -E
http://www.gieson.com/Library/projects/utilities/tuner/
Mar 26, 2014 | Fender Music
Cant tune guitar
They have tuners at the Guitar Center cost about 20.00,ask them to show you how to use it and they will be glad to show you, or if something is wrong with the Guitar that it want tune they will check it out too. Any store that carry's Guitars will have tuners.
Dec 03, 2013 | Fender Squier Affinity Stratocaster...
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
Hi, sometimes, when I try to tune my Martin D15, the tuner is just going crazy, it's kinda impossible to tune my guitar, wrong note appears on every chord I play. My Boss Tu-3 is brand new. I read the...
Could be the level from your guitar is too high OR low. Too low the tuner can't get reliable signal... Too high and the tuner will see harmics of the strings. Make sure you set onboard shape or EQ's flat. You CANNOT tune while playing CHORDS... A single note at a time please...
Sep 09, 2011 | Boss TU3 Tuner
My AG6 tuner its wrong at the moment of intonation. I comprobe it with a computer tunner (a program). I need to now how to tune my tuner. Thanks
Your Fender tuner is crystal controlled and if you set it for A440 Hz, it will be far more accurate than any computer program can generate. Most of these tuners have the ability to be set at different reference pitches. If your guitar intonation doesn't match at the 12th fret, then you have a guitar setup problem, not the tuner. The intonationation is set at the bridge if you have a bridge with individual adjustments.
Jul 06, 2011 | Fender AG6 SparkleTone Tuner
My ibanez Ael20 works for 2 seconds when plugged in and than stops working. I have replaced the batteries.
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
Jun 23, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Music Logo
197 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
