Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hook up snowplow to craftman
How it hooks up
  • 49 Answers
Go to sears.com and click on the PartsDirect link at the top. Put in the model number of the blade and you will see the diagram of the blade and brackets.
Posted on Feb 06, 2009
Wiring digrams for on off switch for a craftmans table saw
Hook the wires up exactly as you removed them.
Oct 07, 2016 | Saws
Beast way to wire up plow lights on a 2008 dodge Dakota sxt 3.7 v6 4x4
Trying To Wire Plow Lights Without A Harness - Snow Plow Forum ...
www.snowplowforums.com/...lighting-wiring/13714-trying-wire-plow-li...
Oct 11, 2006 - 25 posts - ‎8 authors
They both work when I hook up the battery charger to them. ... This way,the plow lights only come on when the plow is plugged in,and ... A relay equivalent to Napa part #AR272 is good, if you give the number at Advance or Autozone they can cross reference it. 92 Dodge Dakota - 7'6" Snoway MT with DP ...Missing: 2008
Meyer Snowplow Install - Part 2 (Electrical) - YouTube
? 10:01
https://www.youtube.com/watch?v=5RSFqO80cLM
May 20, 2009 - Uploaded by CentralPartsWarehse
A real plow install taking place in our on-site, full service shop. In this video we'll show a complete snowplow install taking place on a 2009 ... How much does a complete set up like this cost? ...BEST SNOW PLOWING VIDEO!
Light Wiring for Meyer Plow - DODGE RAM FORUM - Ram Forum
Dec 13, 2015 | Dodge Cars & Trucks
Where do all the gas lines hook up on craftman model 358.791170 on primer it has a long nippel and a short nippel to hook to it is a 2009 32cc model
Take the primer bulb off and use two new fuel lines and dip them both in fuel. Push the primer bulb to see which side returns the fuel, this is the line that will go from the bulb to the tank, the other line goes to the carb.
Sep 11, 2014 | Garden
When i push the left angle button the snowplow raises up
Sounds like you have the hoses hooked up wrong. Switch the 2 hoses, up and left angle and try it again.
Nov 13, 2013 | Cars & Trucks
Wiring spotlights to my snowplow/salter trucks
The single wire is the "hot" wire. The return is through the metal body of the spotlight. Run the single wire through the switch. Make sure that when mounting the light. you scrape off the paint to make sure metal is touching metal.
Nov 18, 2012 | Camping, Backpacking & Hiking
My name is dave...i live in michigan..i have a snow blade hooked up to my craftman 1000 LT..20hp..my question is..should I use craftman 30sae motor oil during the winter months?
During the winter months where the temperature is frequently below freezing, most engine maunufacturers recommend to use a 10W30 SAE oil.
The thinner, multi-weight oil will allow your tractor to start easier in the colder temp. When the temps are higher, just go back to the 30W SAE oil.
Remember to always use a high quality oil. Lawn tractor engines use the same quality of oil as cars do, so get yourself some Pennzoil or Castrol or Havoline or whatever you normally use in your car.
Most lawn tractor engine use about 48 ounces to perform a complete oil change.
Jan 03, 2011 | Craftsman Garden Tractor Weight
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
It looks as your looking into a tunnel
need linkage hook up for craftman tiller 6.0 eng from goveronor to carb
Feb 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
115 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
