Question about Hammering
Need a new oil cap / dip stick for Champion Generator model # 41532
9000 starting watts / 7000 running watts with wireless remote electric start
CarlGehrke
  • 169 Answers
SOURCE: stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Posted on Mar 15, 2009
mamicheddy
  • 79 Answers
SOURCE: Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Posted on May 09, 2009
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
  • 32 Answers
SOURCE: I have a Briggs & Stratton 6.0ohv on a lawn
someone put the wrong cap on your engine. 2 strokes don't have ohv
Posted on Jul 20, 2009
  • 24 Answers
SOURCE: I have an Onan 6500 watt genny in my 36 sea ray
check oil pressure switch
Posted on Sep 18, 2009
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
Dewalt 7000 generator will not stay on
Oil level switch that protects engine is activated. Check your oil level.
May 22, 2014 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
Dec 31, 2013 | Champion 3500/4000 Watt Portable Generator
I have a Champion generator 6000 starting watts modle number 41115 starts and runs for a few minutes then shuts down , has fresh gas and new spark plug.
Is the oil level good, does the low-oil cutoff switch work properly? Try bypassing the aforementioned switch to see if it fixes your woe.
Nov 05, 2013 | Electrical Supplies
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
I can't find were to put the oil on the 1000w 2 stroke generator
Hi, For a 2 stroke you will not need oil in the engine. When you mix the fuel you add oil in the gas.
See the owners manual for details.
Jul 22, 2011 | Watts 1000w 2 Stroke 1000 Portable Camp...
Need instructions for a Sportsman 7000 Watt Electric Start Generator. Can you assist. My generator will start and run for about 10 minutes before cutting off and will not start again. Need to review...
HERE click the here link for the manual with checking my books it looks like the low oil switch or the transition component before it make sure it is on a level surface and oil is at proper level i hope this helps.
Aug 25, 2010 | Electrical Supplies
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Hammering Logo
46 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
